Samsung Model LN46A530P1F LCD display issue
    I have an LCD tv with a display issue. When the tv is turned on the display is wonky, then after about 20 minutes it is normal picture. Is this a display issue or something else?
    Re: Samsung Model LN46A530P1F LCD display issue
    Could well be a tab bond issue, plenty written on what you can do to correct it, albeit temporarily.
      tab bond.
        How difficult of a repair is this and how long does it take?
          Just google "Tab Bonds Badcaps"
            Any screeching through the speakers ? May or may not be related..
            https://www.badcaps.net/forum/showth...208#post525208
              Hello,long time lurker,first time post,i had same issue as original post,decided to have a go at repair,found offending tab,top left,made a shim,worked for 3 days,tried second time and as i applied pressure my finger slipped and my ring hit the tiny resistors behind tab and screen went blank,just hoping someone can tell me whether i have ruined panel or maybe just destroyed t-con,reason i mention t-con is before this happened when i disconnected t-con i got white screen,now nothing happens,thanks in advance
                If its a part that's mounted ON the tab that goes from the glass to the board, then the set is toast.
                Those parts on the actual tabs are the driver-chips and are unreplaceable.
                Give us a picture of exactly what you mean.
                TELEFIX
                  So sorry for delay in getting photo up,i hope this works my ring hit 1 or 2 of the 4 little fuse types above the left tab in photo,tv still has sound and backlight comes on but picture faded away,when i disconnect left side of t-con and reboot i get half white screen,dont know if it means anything,thanks for helping Alastair,have i destroyed the screen ?.
