Samsung LN32B360C5D no picture/sound on HDMI
  • soundindc
    • Oct 2014
    • 5
    • US
    I have a Samsung LN32B360C5D which is working fine via the RF, Component and VGA inputs. The 2 HDMI inputs however, display a blue screen, occasionally a black screen with the input and resolution in the top left corner. The HDMI connectors look quite clean and undamaged under a magnifying glass, and I've ruled out the HDMI cable and the video source. The set does sense an input on HDMI 1 & 2, otherwise they're not selectable via controls, but no picture or sound. Any suggestions would be appreciated.
  • nomoresonys
    • 12274
    • U.S.
    Re: Samsung LN32B360C5D no picture/sound on HDMI
    maybe try a firmware update, if one is available.
    • nomoresonys
      • 12274
      • U.S.
      not clear, are you saying they use to work or not since you've had it?, some tvs have settings where you can block certain inputs with remote etc.
      • soundindc
        • Oct 2014
        • 5
        • US
        The HDMI's haven't worked since I got this 6 months ago, running component and VGA. found the firmware update, put it on a stick, it didn't find the stick, perhaps wrong format, going to try another stick and go from there.
        • nomoresonys
          • 12274
          • U.S.
          situations may differ, but with my update, it said to format the stick to fat 32, it was already at fat 32, so I didn't format, for some reason it didn't work, so went back and formatted fat 32, even tho it already was, this time it worked, no idea why.
          • soundindc
            • Oct 2014
            • 5
            • US
            Most of my sticks are NTFS so I formatted Fat 32 and this model wouldn't see it, went with FAT, unzipped the files, installed and the HDMI ports started working.
            • nomoresonys
              • 12274
              • U.S.
              NICE, glad you sorted it out,
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
              • JohnML1975
                Samsung UA50TU8000W no picture and no sound
                by JohnML1975
                Hello All
                have seen posts on this model in here but my problem sounded different so thought i would create a thread
                TV will not turn on
                There is no standby light
                When I press ON button for remote the red standby light does flash but no picture and no sound
                From the back of the TV I can see the red light on the back of the mother board
                Holding torch to the screen I cannot see a picture
                I removed the back cover
                Observing the boards I cannot see any damage
                I disconnected the main board from the power supply
                the back...
                08-30-2025, 09:40 PM
