PN59D6500 shuts off in 5-15 minutes; HELP!
  • killerz298
    • Dec 2018
    • 11
    Re: PN59D6500 shuts off in 5-15 minutes; HELP!
    Originally posted by chrismurphy
    Just a thought , change all the caps next to the blue transformer on the Ysus board
    The early boards had 3 10 uf ceramic caps that failed and later boards replaced them with 1 electrolytic cap
    The failure of the early boards produced the issue you are seeing
    Hrm... most people suggest changing out the main board. I'll try to do the tests suggested but I'm not the most handy person.
    • killerz298
      • Dec 2018
      • 11
      Got my main board back from this guy from Ebay and the TV fired right up! Let's hope I can get a few more years out of this bad boy. Thanks for the help.
      • bman4
        • Jul 2015
        • 210
        • canada
        #43
        Possibly planned obsolescence. I can imagine samsung incorperating a self destruct to the nand . i can reccomend not updating .
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • petemanuk
          BGA solder balls not connecting - help pls
          by petemanuk
          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
          11-16-2022, 05:21 AM
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
          Multifix 425-01 and 450-01 Rework Flux Datasheet
          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
          - No Clean Formulations
          - Low residue
          - Range of activity to deal with different component solderability
          - Halide free
          - Suitable for dispensing
          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
          Both products are supplied in syringes or cartridges for application by dispensing....
          10-07-2024, 06:02 AM
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
