Vizio VF551XVT possible tab bond failure
  • angrydingo
    • Mar 2012
    • 18
    Hello all, i'm trying to troubleshoot a Vizio VF551XVT LED set.
    The problem with the set is the right half of the screen is pixelated green and yellow. I can make it go away by gently tapping the side, putting a small amount of pressure, or moving it around slightly on the stand.
    Pictures are attached.
    I'm thinking it's probably a tab bond failure, but I wanted to get opinions? possible LVDS cable? T-Con?
  • angrydingo
    • Mar 2012
    • 18
    Re: Vizio VF551XVT possible tab bond failure
    Bump?
    • drussell
      • Nov 2014
      • 144
      You're really probably going to have to take it apart and see exactly where you have to bump, squeeze, push, pull, twist or whatever to figure out precisely where the problem is...
      It's not really something we can magically tell without the set physically in front of us.
      • angrydingo
        • Mar 2012
        • 18
        Alright, I think I've located the problem here
        It's the 2 ribbon cables in the picture. Jiggle them around and the picture changes, get it just right and the picture is how it should be
        Forgive me, I'm sort of new at repairing TV's. I've only done 4 sets and each time, the mainboard was bad!
        Are these ribbon cables the LVDS cables? Whats the best way to unseat them, so i can clean and re-seat them? Or are those the cables that lead to the tab bonds on the panel?
        Thanks!
        • MagicSmoke
          • Feb 2011
          • 275
          Yes the top 2 flat ribbons go to the panel. You can carefully remove them and try cleaning the contacts w/alcohol or electronic contact cleaner. The 2 bottom ones are the lvds cables.
          But the top 2 are the ones that are tab bonded usually. I believe there is a post about trying to repair tab bonds, but for the hobbyist I don't think its feasible.
          • drussell
            • Nov 2014
            • 144
            Those look like the type where you carefully (they are fragile) swing the brown part of the connector upwards from the ribbon cable side to release the grip on the cable.
            I can't tell from that photo where they lead but be very careful with them if they lead towards the panel, you don't want to make the situation worse if they are bonded to the panel at the other end and that's where they are failing. You may still be able to shim the end at the panel with some foamies to get a better connection and some more life from the panel if that is where it is failing.
              Those two flat cables are for connection between the LONG PCB and the T-CON board.
              The tab bondings flexible cables (has drive IC embeded on it also, https://www.badcaps.net/forum/attach...3&d=1401321146) are part the glass LED panel and are bonded to the long PCBs. To remove the cable from the T-CON, you will flip up the light brown tab up to release the cable, you must be real careful to make sure it goes back in correctly. I cannot see on the other end to see if it also has the locking tab or not, pictures are too dark to see.
              The LVDS cable is the cable between the T-CON board and the main board.
              • angrydingo
                • Mar 2012
                • 18
                Thanks for the help guys.
                One of the connections was definitely loose. I could see the picture changing while I jiggled the one ribbon around, and then the cable just fell out! So i flipped up the tab, firmly reseated it, and voila, working TV. Haven't had the opportunity to give it a proper test run, I'll get to that this weekend
                  Great! I hope that is all it needs.
                  • howardc64
                    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                    by howardc64
                    Problem
                    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                    Model & Board Pics
                    Conflicting Spec
                    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                    https://www.shopjimmy.com/vizio-gj-2k1...
                    10-10-2024, 01:16 PM
                  • Nr4ps
                    Vizio DPS-167DP-1 failure
                    by Nr4ps
                    I'm trying to troubleshoot a DPS-167DP-1 A power supply board from a Vizio M552i-B2 tv. The tv would no longer turn on, and I found the usual melting on IC901, with D950B and ZD909 shorted and R915 open. Sounds like this is a pretty common failure, so I replaced all four components expecting it to be an easy fix but it's still not working.
                    I checked D801 and it's fine. I get about 170V DC across the main filter capacitor C800A. I'm not getting any voltage on the 5V standby pins in connector CN101, nor any voltage on the VCC pin of IC901, which is presumably why it's not working --...
                    01-26-2024, 03:53 PM
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
