Samsung UE32D4000 not power on
  • xxcxx
    • Feb 2013
    • 31
    • portuguese
    have a Samsung UE32D4000, the Power LED flashes 2 times and dont power on.
    Anybone have this tips ? I need code to led flashes
    I have some service manuals but dont have electric shematic is this manual dont have code to flash !!!
    BN41-01661A - motherboard
    BN44-00421A - source power
    Someone can help me?
  • sordids999
    • May 2013
    • 2152
    Re: Samsung UE32D4000 not power on
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Kilroys
      • Feb 2014
      • 70
      • Sweden
      Start with the easiest
      Reset TV
      Press and hold "Exit" for 10 seconds
      • xxcxx
        • Feb 2013
        • 31
        • portuguese
        UE32D4000NWXXC
        PD32A0_BSM Power supply
        BN41-01661 Board
        • xxcxx
          • Feb 2013
          • 31
          • portuguese
          Reset TV
          Sorry ,
          Start with the easiest ? what is it ?
          thk
          • xxcxx
            • Feb 2013
            • 31
            • portuguese
            Reset TV
            BN41-01661 Board
            I Put pictures
            • xxcxx
              • Feb 2013
              • 31
              • portuguese
              I Reset and same problema , chnaged al capacitors from power supply ... and blink 2 times !!!!
              • CapLeaker
                Leaking Member
                • 8158
                Seems like there is no schematic for that board available. Measure the DC voltages on the power supply. There is a ribbon cable from the PS going to the main board CNM803. Check all the voltages there and report back.
                You can take the power supply out and check the diodes and transistors for shorts.
                Or you can buy a new one for $60. Depends on how far you want to go.
                • mmartell
                  • Oct 2013
                  • 3189
                  "D" Series is known for failed led strips inside the panel.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • mrtek
                    Samsung UN43NU6950FXZA No power
                    by mrtek
                    Hi
                    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                    Main fuse = OK
                    Back light LED = OK. Power them with aux power source
                    LED output = OK 156V
                    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                    07-20-2025, 08:06 PM
                  • dicky96
                    Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                    by dicky96
                    Hi guys
                    I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                    If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                    If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                    03-24-2023, 06:33 AM
