Sony KDL 40v5810 - No picture, no backlight, no sound; relay clicks, green LED
  • nomoresonys
    • 12332
    • U.S.
    Re: Sony KDL 40v5810 - No picture, no backlight, no sound; relay clicks, green LED
    Ok, so Dangs' detailed instructions worked for him and for poster of #14, Dang had same tv so should work for you too. disregard post #16 as your old sony and mine are from the same year but different types, mine being able to update from usb.
      Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
      by momaka
      I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
      Problem:
      Backlight cycles On and Off.
      Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
      01-17-2019, 11:23 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:33 AM
    • arctor
      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
      by arctor
      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
      04-26-2025, 05:22 AM
    • shahnld
      Sony kdl 65xg9505 green amber blinking
      by shahnld
      Good Day.
      I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
      i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
      green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
      01-03-2024, 03:05 PM
    • alegatorul
      sony bravia kdl-43w756c, no power, no sound
      by alegatorul
      the charger brick has 19,2-19,3 vcc
      changed the inverter board same result.
      where should i start?
      cheers
      11-15-2025, 10:00 AM
