samsung ln52a550p3fxza picture issues
  • shadeengineer
    • Jan 2015
    • 9
    Greetings, a little back story replaced the caps after a failure a little over a year ago now there seems to be something new going wrong. When first powering up the set I get at first a ghosting effect in the back ground with a slight pixalition of red on some areas, this goes to a green pixalition on black areas, this varies in degrees of picture noise for the first thirty minutes or so before clearing up. I suspect the t-con board but wonder if something could be going on with my original repair. On powering up I do hear a click and the red led light flashs three time prior to coming on. I am new to this forum and to troubleshooting lcd televisions, so please bear with me, any help would be greatly appreciated
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung ln52a550p3fxza picture issues
    That looks like an AS15 IC has gone bad on your tcon board. If your not fluent in pcb board repair order a new tcon board for the tv. This is the small board at the top center of the tv. Connects to the panel. If you have a volt meter we c an help you take.some readings to confirm
    • shadeengineer
      • Jan 2015
      • 9
      Thanks once I disassemble would appreciate the help on verifying the problem
        • 12330
        • U.S.
        hello freak, do you think one of those AS15 IC would cause a snowy pic. and no menu?
        • freakaftr8
          • Oct 2012
          • 3743
          No. You would still see a menu. If the as15 fails badly you would probably have an all white picture.
            • 12330
            • U.S.
            thanks freak.
            • freakaftr8
              • Oct 2012
              • 3743
              No problems. Follow the links on this forum on how to test your tcon for a failed as15
              • shadeengineer
                • Jan 2015
                • 9
                Tracked down a replacement T-con board, installed friday and wow, better picture then before the failure. FYI, double check the cables, prior to buttoning up or better yet power up unit if possible before putting the back cover on. I had a cable ever so slightly work out of its slot. Repair took less then an hour thanks for the help
                  09-07-2024, 05:50 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Dodgethis
                  Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                  by Dodgethis
                  Hello all,
                  This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                  09-11-2024, 07:39 AM
