Sylvania LC420SS8
  • ibgm
    • Oct 2013
    • 63
    • usa
    Sylvania LC420SS8
    Hey guys, I have this LCD and it's working fine. The only issue I have is that when I turn the set off, I can hear a slight hiss that doesn't go away. It doesn't bother me, I can barely hear it, but my daughter says it drives her crazy. Any ideas on this? I picked up the set about a year ago, thanks to you folks, I got it going, it had a shorted diode. I just started watching it and it really does seem fine, just wondering if this is something I should be pro-active on. I appreciate any and all advice!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Sylvania LC420SS8
    Umm... follow the noise? The only thing that's always on is the 5V Stby power on the power supply.
    • GraphicMan
      Pioneer A-205 faint noise/hiss issue
      by GraphicMan
      as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
      what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
      out of curiosity what does that mean?
      thanks
      05-19-2024, 11:45 AM
    • dicky96
      LG L90 can't hear callers and they can't hear me
      by dicky96
      Hi. My wife has this problem on her phone.
      She can make calls and accept calls but she can't hear the caller and they can't hear her.
      The ringtone plays fine so the speaker is working.
      However we have discovered that if she answers a call and presses Speaker Phone she can then hear the caller (through the normal earpiece not the speaker) and the caller can hear herl. What is causing this problem?
      As its my wife's phone I will have zero credibility if I can't fix it lol
      12-28-2019, 12:15 PM
    • StriderSubzero
      Sylvania SSC091 - no picture
      by StriderSubzero
      So I think I may have buggered something up.
      The video on this set was working, but the VCR did not work (it would attempt to read the tape, then eject it). I was thinking I could clean the mode switch on the VCR board and reassemble—I was able to do that and get it reassembled, but now cannot get anything to display (and additionally the VCR is not loading tapes properly, so I suspect I didn't get the mode switch oriented correctly when I reassembled it, but I will revisit that later).
      I can see the filament glow when I power the set on, and audio seems to be working...
      03-05-2025, 01:10 PM
    • jayjr1105
      Anyone ever hear of this solder brand before?
      by jayjr1105
      Need some .6mm solder. I gave what was left of my cheap 63/37 to a friend who needed some. Stumbled on this brand. I figured "made in Japan" it must be half decent but it doesn't give flux percentage or flux type unless you can read japanese maybe. Anyone hear of it before? As long as it has 2% flux it pretty much checks every box for me. 63/37, .6mm, 2% or more flux....
      03-20-2022, 02:42 PM
    • saulini
      macbook air a1932 no display but can hear the battery chime
      by saulini
      Hello guys...
      I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following...
      09-08-2023, 09:47 PM
