Sony KDL-70R550A 5 Blinks
  • kenney001
    • Apr 2012
    • 15
    Hello all!
    I am trying to fix my Sony 70R550A LED TV.
    1: TV had no picture, and no sound, but backlight came on and status light stayed green.
    2: If I removed the Tcon from the TV, the symptoms didnt change.
    3: If I unplugged only the left ribbon from the Tcon to the LCD, the display
    would show vertical lines where the logos would be (see pictures).
    4: I ordered a new T-con from Sony Parts. My Tcon is a RUNTK-5348TP-ZA and they sent me a RUNTK-5345TP-ZA, which according to google is for a Vizio M601D. The shipping label says "Part ordered - RUNTK-5348TP-ZA, Part sent - RUNTK-5348TP-ZA". ShopJimmy lists it as a substitute part for the 5348, but i'm not sure how much I can trust that.
    5: When I installed it, the TV now shuts off and blinks 5 times.
    6: If I unplug both Tcon-LCD ribbons now, the TV stays on with a green status light but no picture.
    Is the part I recieved wrong? Or do you think the panel itself is dead?
    I had a post a few days ago, but this issue has changed and that post is burried. If I need to copy/paste this there and delete this post I can do that.
    • 12322
    • U.S.
    Re: Sony KDL-70R550A 5 Blinks
    maybe try a firmware update.
    • kenney001
      • Apr 2012
      • 15
      I dont really know how to do that without the picture. Manual says to plug in the USB and go to "settings." I cannot get to settings without being able to see
      • DLinkOZ
        • May 2013
        • 238
        See what you can do with a dark room and a flashlight. It'll be tough, but could be worth the hassle. I but I picked up a nice Sony a few weeks ago for one of the bedrooms, it had either a 5 or 6 blink error. Updated the firmware and it's been right as rain since.
        • kenney001
          • Apr 2012
          • 15
          I cant see a thing. There is absolutely no picture. The backlight comes on just fine
          • DLinkOZ
            • May 2013
            • 238
            Oh, I misunderstood. Tough spot, then, unless someone is familiar enough to offer step-by-step key presses so you can do it blind.
              If you remove the cables between the LCD panel and the T-CON board then the TV stays on then it sounds to me that it has bad driver ICs or component on the LCD panel, this is the same on the other thread, right?
              The bad thing about this T-CON is that the test points are not label for us to check VGH, VGL Voltages.
              https://www.badcaps.net/forum/attach...4&d=1421452245
              IC301 is more likely to be the one that generates the Voltages.
              You may be able to look up the spec sheet to do some Voltage checking.
              • kenney001
                • Apr 2012
                • 15
                In both Tcons, with both LCD-tcon ribbons unplugged, the TV stays on. With the left cable plugged in, the tv stays on and displays vertical stripes. With the right cable plugged in, the original Tcon leaves the TV on with a black screen, the new Tcon causes the TV to shut off and blink 5 times.
                  • 12322
                  • U.S.
                  that could work, if someone has same model tv or the directions for remote presses.
                    • 12322
                    • U.S.
                    theres firmware here, might be directions with it. http://esupport.sony.com/US/p/model-...3#/downloadTab
                    • Terryfictv
                      • Mar 2011
                      • 124
                      Did the correct T-Con fix this TV ?
                      Good Subs = RUNTK5261TPZC
                      RUNTK5261TPZH
                      RUNTK5261TPZE
                      RUNTK5261TPZZ
                      RUNTK5261TPZG
                      RUNTK5261TPZK
                      RUNTK5261TPZJ
                      RUNTK5261TPZN
                      RUNTK5261TPZM
                      RUNTK5261TPZA
                      RUNTK5348TPZZ
                      RUNTK5348TPZB
                      RUNTK5348TPZC
                      RUNTK5348TPZD
                      RUNTK5345TPZC
                      RUNTK5345TPZB
                      • milkman6453
                        HVAC
                        • Mar 2015
                        • 39
                        • usa
                        I have this tv but in 50 inches, i can assist with a firmware update. Do you want to do it through usb or wifi?
                        Do you have steam, maybe we can message on there.
                        Or here if you would like.
                        • peterwong19660110
                          • Jul 2015
                          • Hong Kong
                          Hi Kenny...did you fixed you 550A? I have same issue of that, no sound, no picture and blinks red led 5 times. Which board did you changed?
                          • Terryfictv
                            • Mar 2011
                            • 124
                            Do you have stream, maybe we can message on there.
                            I have the 70 with 5 blinks.....can you help ?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I bet the TV is shutting down to protect the t-con board from shorting out just like the other sharps and vizios do when there is a panel failure. Do you have a white cable that's a flat ribbon style that goes from the bottom boards on the panel to the side drivers? You could attempt to disconnect both of these cables that go from the bottom boards to the side boards on the panel you should see the cable flaps that hold them in and then try powering it up with your new t-con board with both ribbon cables connected to the t-con
                              • milkman6453
                                HVAC
                                • Mar 2015
                                • 39
                                • usa
                                My offer of help was for someone who had no blink codes. Could access their tv just couldnt see the screen. Im sorry i can not.
                                • StuckWithSony
                                  • Dec 2015
                                  Hi peterwong19660110, have you find any solution for your TV. I have Sony KDL-40HX800 model tv and started receiving the 5 blink error code, no picture or sounds. Replacing the T-Con board would help ?
                                  • iglitare
                                    by iglitare
                                    09-04-2025, 07:13 AM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • rimwall
                                    Sony KD-65x7500D - double image - Tcon or Panel?
                                    by rimwall
                                    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                    11-18-2025, 02:09 AM
                                  • thelankanguy
                                    Sony KD-55X9000F TCON Issue
                                    by thelankanguy
                                    The TV shows a black screen with no image.
                                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                    Later both ribbons were disconnected and TCON voltages were tested.
                                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                    There is also a short to ground in this circled inductor.
                                    Is this a TCON issue or something else ?...
                                    12-13-2024, 12:27 AM
                                  • GoodCapDude
                                    Sony XBR-75X940E intermittent 6 blinks error code
                                    by GoodCapDude
                                    Hi everyone. First post on Badcaps!
                                    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                    09-20-2025, 06:07 AM
