Philips 50pf7521d
  • StevoPasto
    • Jan 2015
    • 9
    • England
    Philips 50pf7521d
    Bought this on eBay locally for £10
    In the description it appeared to have a pink screen with some black blobs either side of it (I've attached a photo of said blobs)
    Took it home and tried to turn it on and nothing, heard a relay click but nothing at the front
    Removed the back panel
    Green LED's on the power supply come on but there is a constant flashing of another green LED on the circuit board directly underneath it (indicating a fault perhaps?)
    I read somewhere about the C8059 and C8060 caps on the power supply perhaps being at fault so I took it to work and replaced them with some new 25V caps
    After reassembly it now turns on but I'm still left with a screen that is half pink and half blue
    I've circled the LED that is constantly flashing
    Any advice would be much appreciated, I have a digital multimeter just unsure on where to test etc
    Thanks for your time
  • Shinju
    • Mar 2014
    • 1239
    Re: Philips 50pf7521d
    You will need to check your voltages on each board Ysus,Xmain and Power supply. There is a sticker inside the panel telling you these voltages.
    Can you post it please?
    • StevoPasto
      • Jan 2015
      • 9
      • England
      Is this what you're referring to?
      • Shinju
        • Mar 2014
        • 1239
        Yes, VA/VS are going to have test points on your power supply, VSC will be on your Ysus the board to your left and VE will be on your Xmain the board on your right.
        test these voltages and report back, they should match the sticker with in a couple of volts if they are WAY off then you have a possible short.
        Be very careful when probing around high voltage possible injury or further damage.
        To me it looks like the Xmain has failed but lets run the ropes and see.
        • StevoPasto
          • Jan 2015
          • 9
          • England
          Unfortunately I shorted out VE and ground
          The unit seemed to power down and all the LED's come on as before as does the screen itself I just cant seem to get a reading from any of the test points now, they show some readings but they jump around and are negligable.
          What possible damage could I have caused? I'll have another go at it tomorrow, it's probably wise to get some sleep before I wreck it
          • StevoPasto
            • Jan 2015
            • 9
            • England
            Still can't seem to get any readings from it..
            Now the power supply turns on, relay clicks as before, but now after approximately 7 seconds it turns itself off and the green LED's shut off
            I think last nights testing efforts made it a whole lot worse
            • Shinju
              • Mar 2014
              • 1239
              Sounds like you might have shorted out a sustain board, the plugs to the x and y boards and see if your SMPS a stays up and running.
              • drussell
                • Nov 2014
                • 144
                Are you sure you didn't just blow a fuse in your multimeter? I assume you had the probes in current rather than voltage/resistance measurement.
                • mmartell
                  • Oct 2013
                  • 3189
                  If your screen comes on then your meter is hit.
                  • jimjoe123
                    LCD TV Green/Pink screen problem
                    by jimjoe123
                    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                    Then each time...
                    02-23-2020, 01:29 AM
                    Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                    This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                    09-06-2024, 09:30 PM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • aidanmo
                    Philips 43PUS7506/12 - Loud blown out sound
                    by aidanmo
                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                    • Using the internal speakers, it always happens.
                    • Using the headphone jack, it never happens.
                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                    02-28-2025, 03:13 PM
