Philips 47PFL7422D/37 backlight comes on, sound works, no picture.
  • 77slurm77
    • Jan 2015
    • 10
    I was given an older Philips 47PFL7422D/37 that was no longer working. The TV turns on, the speakers make the "pop" noise, the blue power LED is solid, the green lights on the mainboard are not blinking erratically or anything but I cannot get a picture to come up at all. Pressing the Menu button does not display anything on the screen. I have found a way to use the Menu button in combination with the channel button to switch inputs and the old yellow, white, and red connection is producing sound but no picture.
    Any ideas?
  • capkid
    • Oct 2010
    • 1339
    Re: Philips 47PFL7422D/37 backlight comes on, sound works, no picture.
    My guess would be a t-con issue. The t-con fuse blows in some of these Philips LCD TVs. I'd start there.
    LG Plasma Mal-Discharge Correction Service
    • kevinjo
      • Aug 2014
      • 49
      Believe it or not, I had this TV a few months ago and found a 100uf 16 volt cap worn out. Replaced and everything was fine and is still fine from what the customer says. I have had other Philips with similar issues. So check all 100uf 16v caps and if they test bad..change them. Not sure if it is your issue or not but with Philips..good place to start. This usually happens on the main boards not the power.
      • CapLeaker
        Leaking Member
        • 8325
        Easy check: Check with and oscilloscope the LVDS signal on the main board. Press the menu button on and off all the time, while you are looking at the scope. IF the LVDS signal changes on the scope, you know the mainboard is fine. Also make sure all the fuses are good on the T-Con board. You can try also heating or cooling your boards, see if that yield a result.
        • 77slurm77
          • Jan 2015
          • 10
          Thanks for the responses and sorry for the late response. I don't have any tools to test but from what capkid said and seeing a few videos I'm guessing it's the T-Con board. I have ordered a replacement so we shall see. Thanks again everyone! I was about to give up on this thing. I will update the post once the replacement board comes in.
          • 77slurm77
            • Jan 2015
            • 10
            This was it!!
            I replaced the t-con board and it's working like a champ!
            Thanks everyone!
            • CapLeaker
              Leaking Member
              • 8325
              Thanks for the feedback!
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • aidanmo
                Philips 43PUS7506/12 - Loud blown out sound
                by aidanmo
                I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                I thought maybe the speakers got damaged, so I replaced them - no dice.
                • Using the internal speakers, it always happens.
                • Using the headphone jack, it never happens.
                • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                02-28-2025, 03:13 PM
