Is There Some Earthly Reason my Meter Can't Read Vsc and -Vy ???
  • mmartell
    • Oct 2013
    • 3189
    Re: Is There Some Earthly Reason my Meter Can't Read Vsc and -Vy ???
    Haha. I've had this meter apart several times so first I'm going to make sure I didn't assemble it incorrectly disabling any factory shielding.
    Maybe I'll take some pics while I'm doing it.
    • retiredcaps
      • Apr 2010
      • 9271
      Yes, clear focused pictures always helps.
      --- begin sig file ---
      --- end sig file ---
      • mmartell
        • Oct 2013
        • 3189
        I bought a used Greenlee dm-210a for a shade under $50us. Still intend to dissect the rcc510 as time permits. Thanks for your input.
        • retiredcaps
          • Apr 2010
          • 9271
          If you got it on ebay, that one that sold today looks to be in decent condition with the standard Brymen silicone like probes.
          The difference between my DM-200A and your DM-210A is the temperature function.
          If you want to see the insides, modemhead did a photo teardown.
          http://mrmodemhead.com/blog/gallery/dm200a/
          You should be happy with it. It updates the display fast (5 times/sec), has large digits, compact size, good input protection and fast continuity.
          PS. The auction only listed USA shipping. How did you get the seller to ship to Canada?
          • mmartell
            • Oct 2013
            • 3189
            Yep that was me. I live in a border town and my wife works in Detroit so I get all my goodies shipped there.
            F*ck Canada Post and f*ck the bureaucrats who delight on holding up the passage of goods into Canada.
            • mmartell
              • Oct 2013
              • 3189
              RCC510 (Fine Instruments Model 183) disassembly for your perusal...
              Quality looks ok to me but the rear shield is connected to the ground with a spring which may or may not be making a good enough contact.
              What you think ?
                Well, the HRC fuses are a pleasant surprise. The ground tag is important for the shielding. If it is not making proper contact that would explain your issue.
                • mmartell
                  • Oct 2013
                  • 3189
                  Yes that's why I mentioned it in light of what you had said previously. Maybe I will solder a wire directly to the two surfaces or is the distance between the two critical ?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Absolutely.
                    Those Bussman are the same fuses found in Fluke meters. They are anywhere between $5 and $10 each.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      I would just extend the spring a little bit and clean both the spring and contact area with some IPA.
                      BTW, in your picture, the rotary switch shows some sort of potential conductive debris/carbon (circled in red). You can clean it with a toothbrush and IPA. They may cause problems in the future like this modemhead blog post.
                      http://mrmodemhead.com/blog/fluke-83-iii-rotary-switch/
                      • mmartell
                        • Oct 2013
                        • 3189
                        I did lengthen the spring and clean the rotary switch contacts while I was in there. The spring however is a PIA as it is prone to fall out of its place if not extremely careful during reassembly. Maybe it should be tacked on the backside to the shielding plate. Will update when I do a measurement with floating ground to see if it has improved.
                        • mmartell
                          • Oct 2013
                          • 3189
                          I made a Vsc measurement tonight on an LG plasma and I swear I saw a proper reading briefly before the display quickly switched to the nonsense reading I'm used to. There may be something wrong with this meter internally. May investigate further later on but as for now another meter is on the way and there are things needing repair !
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Has the Greenlee arrived? Have you tried the Greenlee measuring Vsc and Vy?
                            • mmartell
                              • Oct 2013
                              • 3189
                              Yes it has and yes I have and it gives me proper readings It does give a quick reading on Auto Range and the backlight is a nice touch. Also need to get used to the fact it has a quickstand so I can quit craning my neck in some situations lol.
                              Happy with the purchase - thanks for the recommendation.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Good to hear. Check the fuses on the Greenlee to make sure they are not blown. A lot of ebay sellers list items as working, but the fuse/fuses is/are blown.
                                If you want to try and fix the RCC, I have some ideas on what to test and now that you have another meter, we can actually measure the RCC internals.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4978
                                  • New Zealand
                                  #36
                                  Is it possible the rail being measured is so dirty the interference is coming through the test leads?
                                  -David VanHorn
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Still would be a problem with the old meter as the new one measures fine.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Absolutely, just tell me what you would like me to measure.
                                      And the new meter would still work with blown fuses ?
                                      • R_J
                                        • Jun 2012
                                        • 9556
                                        I had a simular problem measuring voltage on a Vsus board, using an LG DM-311. I would get over voltage reading even on the 1000 volt range, Using my Fluke 8080a I measured the correct voltage which was around a 100 volts, I suspect the LG was adding the peak of the ysus drive signal on top of the dc voltage. or the drive signal was getting into the lg meter confusing it? The LG is a cheap meter compared to the Fluke
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Yes. The fuses in 99.9% of the digital multimeters sold in recent years are there only to protect the current ranges. The meter will happily measure voltage, resistance, etc without any fuses in it.
                                          You should take the fuses out of your Greenlee and inspect them to make sure they are the correct values in case the seller replaced them and that they are ceramic/HRC and not glass.
                                          The only multimeters that I know, first hand, that uses fuses for proper operation of the multimeter were sold by Radio Shack. With Radio Shack declaring bankruptcy, you won't have to worry about that now.
                                          PS. Dave Jones did a video of the Brymen BM257. Most of what he says applies to the Greenlee 210A.
                                          https://www.youtube.com/watch?v=tXu0lsOjvDs
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                          • Stephan Mathers
                                            EDMI ATLAS MK10 Electronic Meter Discussion
                                            by Stephan Mathers
                                            Greetings, new guy here but always interested in the crazy universe of modding
                                            We just finished construction of around 25 vacation houses, all inside the same private area.
                                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                            05-20-2025, 09:09 AM
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                            Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                            I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                            https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                            What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                            03-30-2025, 11:05 AM
