Vizio M420NV Powers on for a few seconds then resets
  • kisk
    Computer Tech
    • Jan 2014
    • 78
    I have a friend who's Vizio is having issues. I have the set here and have recapped the entire power board but still having the same issues.
    From a cold start (>10m) the unit will stay powered on for about 2 minutes. After that time, it reboots. Each time it reboots the time till failure decreases. After about 5 reboots it only stays on for maybe 10 seconds then continues to reboot. If you leave the unit unplugged for about 10-15 minutes it will stay on for another 2 minutes or so before doing this all over.
    He had actually called Vizio and they were going to send someone out and "replace the power board" for $199. Hardly worth it since I was almost sure it was a cap issue because of the symptoms, however it wasn't.
    Anybody up for helping me diagnose this sucker? Looks like a combination power/inverter board and I suspect something is heating up and then failing -- I'm just not sure where to start and I can't find a schematic for this thing. It doesn't seem like the normal eeprom issue you normally see with the Vizios.
    I have my dmm ready! Thanks!
    EDIT: I did not replace the 2 big 450v caps. I believe these are know as the filter caps?
  • kisk
    Computer Tech
    • Jan 2014
    • 78
    Re: Vizio M420NV Powers on for a few seconds then resets
    oops, pics:
    And if I need to take additional pics let me know!
    • kisk
      Computer Tech
      • Jan 2014
      • 78
      Well ended up ordering a new power board for this thing and its doing the same thing.
      I know vizios are known for bad eeproms. Would what is happening here be in the same realm as a bad firmware chip.
      Whatever it is, it seems like something is warming up, expanding, then faulting. Not sure where to go from here other than blindly order a new eeprom or mainboard. Any ideas?
      EDIT: BTW, I was going to try and flash a newer firmware to see if that fixed it but I can't find any types of downloads on the Vizio site whatsoever.
        Shopjimmy sells EEPROM so I will not be surprised if you have EEPROM problem.
        http://www.shopjimmy.com/catalogsear...q=Vizio+M420NV
        And also these two ICs that you should look and see what they are:
        http://www.shopjimmy.com/vizio-3642-...for-m420nv.htm
        You may want to contact SJ to see what they will say about your symptom, they are really helpful on pointing out the cause of the problems.
        • riki_22
          ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
          by riki_22
          I’m working on an ASUS B5402CEA notebook.
          B5402CEA_MB_R2.2
          HA4YT LA-L861P
          REV:1B
          The board powers on, fan spins for a few seconds, then it shuts down by itself.
          I suspect the BIOS might be corrupted.
          Could someone please check and clean (repair) the attached BIOS dump?
          I’ve also attached a few photos of the motherboard for reference.
          Thanks in advance for your help!
          11-03-2025, 04:38 AM
        • AlexVG
          Macbook A1466 820-00165 resets every 10 seconds
          by AlexVG
          It have had a problem with U7100 and short circuit in Q7130.
          I replaced them.
          It starts now and waiting 20 seconds and then starts to reset PM_SLP_S4_L every 10 seconds.
          Almost all voltages rising
          except U3090 and U3210 (LED) - not receives enable signal.
          U4500 is trying to rise - receives enable only 2-3 seconds
          Here is my measuring of important signals.
          What else could be the problem?
          I need to help.
          Thank you an advance....
          11-09-2023, 07:19 AM
        • csmith
          Vizio D50u-D1 Powers up no picture
          by csmith
          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
          issue. Set will power up with remote but not power off....
          07-11-2025, 11:52 AM
        • ResoluteHawk
          Alienware 17 R3 (LA-C912P) Powers on then powers off after 4-6 seconds
          by ResoluteHawk
          I have an Alienware 17 R3 (board is a C912P) that I recently starting trying to repair. Originally the issue was the charger going into protection mode when plugged in to the laptop. I found a short on the motherboard (one of the capacitors on the back of the board under the DRMOSes for the CPU) and the charger when plugged in now doesn't go into protection mode anymore. The laptop powers on, the lights on the keyboard, alien head, and alienware logo light up, and the fans spin. The issues are:
          1) The battery doesn't charge. I've probed the charger jack and it's only receiving 0.633v...
          06-17-2022, 01:04 PM
        • videotronics
          D43-E2 vizio dark gray display 36 seconds restart
          by videotronics
          Hello everyone, the budget 4k 2017 model Vizio on power up the white led fades and the backlight illuminates, the display is dark gray modulating slightly brightness until the set restarts on 36 seconds interval. Power supply 5v 12.7v 21v are all good. Any recommendations to test the panel and display drive t-con board and mainboard will be appreciated.
          08-24-2023, 09:04 AM
