Toshiba 328L67U 1 Green, & 1 Red small Vertical Lines
  • Tayninh55
    • Sep 2011
    • 153
    Hi, I don't have the TV in my possession, it's a Toshiba #328L67U, just asking question for brother-in-law. He turns the tv on, and picture is great, just has a narrow vertical green line about 1/3 from left of screen, and a narrow vertical red line about 1/3 from the right side of screen. After the tv is on for an hour or hour and half, both lines disappear and everything is fine until the next time he turns it on (cold start up) again,,,,,,then repeats the same way. Could this be a T-Con ribbon connection-alignment problem,,,,,,,,,why would the lines go away the way they do without someone moving something? I know, probably could be a lot of things,,,,,,,,,,,but just asking. Thanks!
  • Tayninh55
    • Sep 2011
    • 153
    Re: Toshiba 328L67U 1 Green, & 1 Red small Vertical Lines
    Come on guys, give me a break here, I know I'm not giving you much info, but tell me what you think. Do you think this tv can be fixed economically, or do you think the screen itself is beyond repair? Is it possible that a cold or cracked solder joint could possibly cause this screen to "clear itself" up after it has been on for an hour or so and heats up?
    I would not have used an icon like "wtf", if it hadn't been readily available!
      • 12331
      • U.S.
      have him try putting palm on front top of frame where line is and tap the back lightly, if that don't work tap a little harder, let us know if it works.
      • selldoor
        Slow Learner
        • 7870
        Yes it could be the lvds cable between the main and the tcon. There is usually a lot of heat in that area and as it heats up the connection may improve.
        Things to try . when the set is cold heat the cable connector gently with a hair drier and see if the lines disappear.
        Try just gently moving the cables on the tcon.
        Remove the cable and clean the connectors using IPA then reseat.
        Sadly it could be the permanent connection to the panel which could get worse with time
        • Tayninh55
          • Sep 2011
          • 153
          Thanks for the replys,,,,,,,,,,,,,,,,,,,,,,the reason I don't have the set is because it is football season and he is still using it. I didn't want to "tear into it" and leave him with no television to watch the games. We will try what you said and see what happens! Thanks again.
            Probably a bad LCD panel.
            • Tayninh55
              • Sep 2011
              • 153
              Well guys, we tried all the banging, and twisting, and tapping that we could to see if something might be loose or a connection moving, without tearing the set apart, and nothing we did affected the two lines on the screen. He decided that he'll watch it, as it is, until it goes out more completely, and then have it torn apart. Thanks for the suggestions!
              • pni
                LG 49uf695v vertical coloured lines
                by pni
                Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                11-14-2025, 03:15 AM
              • 265chemic
                Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
                by 265chemic
                Hi All,
                I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
                My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
                Below are some photos...
                03-23-2022, 04:53 PM
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • arctor
                samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                by arctor
                hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                04-26-2025, 05:22 AM
