Panasonic LCD TV turns off after few seconds! HELP
  • kajaalyo
    • Jan 2015
    • 25
    • slovenia
    Hy,
    I want to fix Panasonic VIERA tx-l32c10p LCD TV. But I cant find out wich part is bad. I recorded the video of whats happening, but I will describe the problem anyway.
    1. When I turn tv on it turns on normaly, except the right side of display is darker than left side (this is not visible on the video).
    2. Tv then turns off by itself after few seconds.
    3. Red light starts blinking and it doesnt stop at all, except if I press any button on the remote (than it turns off and just blink i press any button on the remote).
    4. In order to turn TV back on I have to turn it off and on with master power swich.
    IF I QUICKLY PUT TV TO AV MODE (So there is no picture, except the AV sign) TV WONT SHUT OFF AND EVEN IF I OPEN MENU AND IT STILL WONT SHUT OFF. However if i plug in my digital converter TV will shut off after few seconds of showing picture
    The video:
    https://www.youtube.com/watch?v=NQlGGQWFCl8
    There is a picture of tv with back cover off in attachments.
    I tried to disconnect every single component one at a time to see if anything changes but no luck:
    -Because right side off the screen is darker and silent buzzing sound is coming out of two boxes on backlight circuit board (No.0) I tought that there is a problem with backlight or backlight circuit board (No.0).
    I disconnected 2 cables for backlights (No.1), but there was no difrience except display was not lighted.
    Than I disconnected whole backlight circuit board (No.2), but there was no difrience again.
    There is a blue LED on the backlight circuit board (No.3), there is a video of its activity!
    There is a picture of backlight board (No.0) in attachements!
    https://www.youtube.com/watch?v=rb3j4iCbRGs
    I also tried to connect No.1 left connector to socket for right connector and No.1 right connector to socket for left connector to see if display will be darker on left side instead on right side, but there was no change.
    I measured resistance of backlight (No.1) connectors and they are the same: 0,5 OHM!
    I also measured resictance of No.1 sockets and they are also the same: 0,3 OHM!
    -I tried to disconnect display board, speakers, board with buttons (i jumped the connector to turn tv on), LED and IR sensor board, but there is also no difrience.
    -I ofcourse also put tv to factory settings.
    I CANT FIND ANY BAD CAPACITORS, BAD CONTACTS, NOTHING FRIED UP OR ANY DAMAGE ON THE BOARDS AT ALL!!!
    There is SELF TEST info in the attachments -I found default resoults in service manual and confirmed that they are the same.
    I think that PSU is bad, but im not sure. What do you think?
    • 12331
    • U.S.
    Re: Panasonic LCD TV turns off after few seconds! HELP
    be careful when working with power supply, HIGH VOLTAGE, on primary side, can be deadly, start with checking everything labeled F on the boards, F=fuse, look m over real goods, they can be really small.
    • kajaalyo
      • Jan 2015
      • 25
      • slovenia
      Hy, thanks for your help. I will try do that. I will let you know if i find anything.
      • kajaalyo
        • Jan 2015
        • 25
        • slovenia
        Hy again i found only one fuse marked as f101 and its OK! Do you have any idea what this could be?
        thanks
          • 12331
          • U.S.
          cant see your backlight board very good, look it over real good, see if you can find a fuse to check.
            • 12331
            • U.S.
            then I'd check power supply voltages, there should be a legend of expected voltages, right beside the pins where the connectors are.
            • kajaalyo
              • Jan 2015
              • 25
              • slovenia
              Hy, i appreciate you help!
              I will try to locate fuse on backlight board! Voltages are not marked on board, but i found them in service manual!
              Do i need to look for voltage when disconected and powered on by shorting 2 contacts or do i need to look for voltage drop when tv turns off? Thanks
              • CapLeaker
                Leaking Member
                • 8352
                Your first video, the picture looked brighter on the left side, that it is on the right side. Is that just on the video or really like that? Look at the voltages on the backlight driver board. There should be a few GND a few 24V, a BLON, a backlight adjust and may be an error line. For now check the 24V out and see if they disappear with the screen going blank.
                My guess is that it disappears. However, you can test your backlight, by disconnecting all other boards from the power supply, force the power supply on and just run the backlight. See if it keeps running.
                • kajaalyo
                  • Jan 2015
                  • 25
                  • slovenia
                  If you stand in front of the TV picture is darker on right side. BLON is pin that i need to short out to turn PSU on or i need to measure voltage from it, if so what should be the voltage?
                  If voltage disappears this is bad PSU than?
                  I will also try to test backlights like you tell me!
                  I will let you know about resoults!
                  Thank you.
                    • 12331
                    • U.S.
                    this could be a capacitor issue, they dont have to bulge to be bad, could also be a prob. with mainboard.
                      • 12331
                      • U.S.
                      I think you jumper stby to bl-on, someone correct me if I'm wrong, not exactly sure.
                      • kajaalyo
                        • Jan 2015
                        • 25
                        • slovenia
                        This is wiring diagram, i marked the connector with green circle. I dont get it, i must connect STBY_5V6 to what? thank you!
                          • 12331
                          • U.S.
                          https://www.badcaps.net/forum/showthread.php?t=17997 heres a good post, #5 describes the jumper a little, it is from stby to ps-on.
                          • kajaalyo
                            • Jan 2015
                            • 25
                            • slovenia
                            Mine does not have ps-on connection, so i must connect stby to something else, maybe relay?
                              • 12331
                              • U.S.
                              I dont see ps-on, I cant figure it out ether.
                              • kajaalyo
                                • Jan 2015
                                • 25
                                • slovenia
                                :S I tried to connect relay to stby but nothing happends :S
                                  • 12331
                                  • U.S.
                                  maybe wait for some better guidance, you dont want to short anything out.
                                  • kajaalyo
                                    • Jan 2015
                                    • 25
                                    • slovenia
                                    No worries, first i powered tv on and test resistance between these two connections, I found that resistance is 0. Than i tried to connect those two without motherboard!
                                    • kajaalyo
                                      • Jan 2015
                                      • 25
                                      • slovenia
                                      Ok i figured it out. There is another connection TV_SUB_ON_RELAY_ON in order to turn psu on i connected TV_SUB_ON_RELAY_ON with RELAY_5V6 and STBY_5V6,
                                      Now i can hear relay click when i plug corn in, but nothing shows up :S
                                      Here you can see (left red circle) that there are some ..._ON connections for backlight board, do i need to connect those to something as well? Right circle is that TV_SUB_ON_RELAY_ON that i found.
                                      • CapLeaker
                                        Leaking Member
                                        • 8352
                                        You also need to jumper the backlight on to the 5v standby to force it on
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • PanasTC
                                          Panasonic TC-60CX800U turns off after 2 seconds.
                                          by PanasTC
                                          Panasonic TC-60CX800U with Power board: TNPA6060 1P
                                          The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
                                          Also, I could see HDM in the top corner for a second.
                                          Is it possible that the issue is a bad LED light that forces the TV to turn off?​
                                          11-27-2023, 09:02 PM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
