le40d503f7w screen problems help appreciated
  • beliver
    • Jun 2013
    • 27
    • york
    hi tv 40 in lcd green banner across top about 3rd of screen plz help if u can thanks in advance.
  • beliver
    • Jun 2013
    • 27
    • york
    Re: le40d503f7w screen problems help appreciated
    plz help anybody?????
    • sordids999
      • May 2013
      • 2152
      i think it looks like panel failure or even tab bond
      • beliver
        • Jun 2013
        • 27
        • york
        right have open tv can locate 2 tabs should there be more ???
        have seen the video how to repair if this is the tabs.
        but can only find two coming of long pcb sorry total newbie lol
        • beliver
          • Jun 2013
          • 27
          • york
          update after about 15 mins veiwing after inital warm up screen ok and bar vanishes.
          so my question could this still be the panel faliure???
          thanks in advance
            • 12187
            • U.S.
            could be bad capacitor, they dont have to bulge to be bad.
            • beliver
              • Jun 2013
              • 27
              • york
              the capacitors are cheap is it just easier to replace all ???
              • saddle_au
                Waste Warrior
                • 121
                What are the tab bonds?
                Background info.
                Your LCD panel needs to drive an awfully large number of horizontal and vertical lines so that individual pixels can be addressed. You cannot do that easily in a parallel way, so they have a scheme where main boards clock data on a couple of wires at high speed to a timing and control board (TCon). TCons take that in and reclock it in a particular way on 80 to a 100 wires to the panel and the panel itself has to take the 80 to a 100 and turn them into 1000's of lines.
                There will be two or more cables from the TCon board to the panel, but there are chips on the panel itself, usually embedded in flat cables sticking out two or three sides of the glass. One side of the panel usually attaches to a PCB (top or bottom) via 4/8/12 flat cables which is used to spread the signals from the TCON to wires on the panel. There are chips on those flat cables and the cables themselves are not socketed. They are called tab bonds and are joined to the PCB and the panel by a gluing process that allows vertical current flow in the glue but not sideways.
                This glue fails sometimes and re gluing it is virtually impossible for you and me due to the ultra fine tolerances, special temperatures/pressures required and the cost/getting some of the tab tape.
                He's one being attached https://www.youtube.com/watch?v=jorqLkOVI6Q
                Tab chips on the top of the screen convert information to column lines and there are also tabs on the sides of the screen where chips on the tabs convert signals into row information.
                Any of these can fail and the screen becomes a throwaway. Sometimes the chips on the tabs fail (throwaway), sometimes the chip has not failed, the connection from the chip to the tab fails and can be maybe recovered with pressure (permanently push on it somehow) but this usually is temporary, although Sony 46 inch screens seem to go years after pressing on column tab chips which is what usually fails.
                Hope this helps.
                  • 12187
                  • U.S.
                  thanks in advance
                  doesnt seem like panel failure, panel failure is more constant.
                    • 12187
                    • U.S.
                    lots of folks just replace them all to eliminate the possibility.
                    • beliver
                      • Jun 2013
                      • 27
                      • york
                      cheers guys appreciate help
                      • jean luc ferre
                        laptop hp g72 b52sf screen problems
                        by jean luc ferre
                        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                        i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                        06-07-2025, 03:27 PM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
