Vizio vw42lfhdtv
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • RDC55
    Vizio a320-a0 eeprom
    by RDC55
    I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
    Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
    04-28-2021, 09:06 AM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
