Vizio vw42lfhdtv
    Re: Vizio vw42lfhdtv
    Originally posted by fixerupper75
    I jump the p_s on and got 12v and 24v but didn't get a blue screen or was I suppose to get a blue screen.
    it needs BL_ON signal, on the connector between the power supply and the inverter board there should be three pins labeled as A, B, and C. I do not remember which one is BL_ON and which one is dimming control.
    It may be easier to locate the BL_ON pin on the inverter board, it should be >2.5VDC for backlights on.
    What is the P/N of U44?
    So right now after the cap is replaced you still do not have PS_ON?
    • fixerupper75
      • Oct 2014
      • 125
      • us
      A=.125
      B=.030
      C=no pin
      U44 part no. k021 G9117
      That's right after replacing the cap still no ps_on.
        OK, you do not have BL_ON or dimming signal either, the U44 will not have any voltage until the main power supply is turned on by the main board.
        At this point you will need new main board.
        • fixerupper75
          • Oct 2014
          • 125
          • us
          Ok thanks for all the help!!! I will keep you posted.
          • nomoresonys
            • 12276
            • U.S.
            must be a little different than a sony, when my mainboard was disconnected from power supply the backlights popped right on.
              It depends on if the power supply board has build-in pull up resistors for the PS_ON and the BL_ON or not, most of the newer SAMSUNG and SONY have pull-up resistors now for easier diagnostic.
              • nomoresonys
                • 12276
                • U.S.
                #27
                Thanks for clarification budm, had me puzzled.
                • fixerupper75
                  • Oct 2014
                  • 125
                  • us
                  #28
                  Replaced the main board and Bam.....We have life!!!! Thank to all my first dumpster save.
                    Thanks for the repair feedback.
                    You should record all the Voltage reading on the power supply board, main board when TV is off and when TV is on so you will know what they should be.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • RDC55
                      Vizio a320-a0 eeprom
                      by RDC55
                      I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
                      Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
                      04-28-2021, 09:06 AM
                    • SidneyCanadas
                      93C46 and 93C56 EEPROM
                      by SidneyCanadas
                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                      06-14-2023, 01:16 PM
                    • cstout
                      DeLonghi AC Remote only accepts 3V
                      by cstout
                      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                      I can't find any schematics...
                      06-03-2024, 03:53 PM
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
