Fault on panasonic veira th-58pz800b
  • 1967tux
    • 29
    Hi all i am new to the forum and was hoping to find some help repairing a Panasonic th-58pz800b. The tv does not have a red flashing light problem and starts up ok. my problem is the screen only shows about 1/3 of the full screen on the right hand side and the part that does show is very distorted and has a red tinge to it , the remote seems to work and scroll through the menu ok (from what i can make out). On the test screen It shows some of the different test patterns but only on the same 1/3rd of the screen and again very distorted and with a red tinge. I have also disconnected the main board and i do not get the white screen. i am not sure which board is at fault when i got the tv it had a red flashing light issue and i traced this out to a blown chip on the d board, i replaced the d board and that is where i am at the moment, any help would be greatly appreciated. is the d board still at fault as it is a second hand one from ebay? or should i be looking for another issue? i have included some pictures of the screen.
    Re: Fault on panasonic veira th-58pz800b
    Could you supply a picture of the fault?
    • 1967tux
      • 29
      Hi Tom have posted some pics of the screen.
        I would suggest you re-seat the LVDS cable. I had a vaguely similar fault:
        https://www.youtube.com/watch?v=4gL_...c&noredirect=1
        caused by a loose LVDS cable
        • dj_ricoh
          • 2073
          that`s your channel?
          saw your videos way way back !
            Yes that's my channel...
            • dj_ricoh
              • 2073
              Cool!
              • 1967tux
                • 29
                hi tom thanks for your suggestion i already watched your video very good and informative. I have tried the lvds cable and it has no effect. i also watched the one on how to test rest of the tv with the main board disconnected i am not able to get the white screen. I dont think the screen is bad as the side that is not working seems to be primed, i am wondering if the fault still lies with the d board or some where else.
                • 1967tux
                  • 29
                  just a quick up date i have now fitted a replacement ss board as one of the chips was also blown on that. the tv now has a good picture but only on 1/3rd of the screen. am i right in thinking that this is the c2 and c3 buffer boards ? is there any way i can test to confirm this or is there something else that can be causing this. any help or advice would be greatly appreciated.
                  • 1967tux
                    • 29
                    have attached photos of how the screen looks now
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      I'm thinking something is wrong with the control board. Or logic board as its also called.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Usually whatever xontrolls the C buffers. Try reseating cables first. Especially if someone else has been into it before. They sometimes are a trick to reseat them and someone could have not seated them correctly
                        • 1967tux
                          • 29
                          have tried reseating cables no change, tried replacing c2 and c3 no change the original logic board had a fault and i replaced this how ever the board i replaced it with was the same number tnpa4439 but it was from a 42" tv could this be the problem? the board looks identical but im wondering if this could be a software type issue ??
                            • 12323
                            • U.S.
                            wonder if a firmware update would put it right?
                            • Shinju
                              • Mar 2014
                              • 1239
                              Does this new logic board have a suffix at the end of the TNPA4439? The 58PZ800B Logic board does not. These suffix are very important to follow, if you got a logic board out of a 42 chances are its not compatible.
                              With my experience with Panasonic plasma's it is very important to replace parts with the exact same number and suffix.
                              • 1967tux
                                • 29
                                Yes the original had no suffix the new has bf so would you say this is the probable cause? and would it be possible to update the firmware to rectify this or just get a board with no suffix?
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Hard to say to be honest, is there a FW update available? Also when you use a smaller panel spec control board the screen is usually whole but fitted to the size it was intended for for example it would be 42" on your 58" screen.
                                  To me you have more wrong if you are only getting 1/3 of the screen before and after then you have issues elsewhere too.
                                  when you changed your C buffers did you try them with the old damaged control board or your new one?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    I think you may have to try and source the correct D board. The 42 only has 2 c buffers, yours has 3 so it may be an addressing issue.
                                    Tom may have a better idea
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      This as well.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        longshot but only other thing to suggest is swap ic9303 and ic9001 across from the old board but either of those eeprom / flash IC is corrupt then you may transfer whatever problem the original had.
                                        ic9303 is 48 pins, 9001 is 8
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
