lg 42lb7rf "Reverse Colors" Problem
  • kobkobk
    • Sep 2011
    • 28
    dear friends hi,
    my lg tv 42'' lcd with display problem,at last days do not turn on normally,i open and sow bad caps at the p.s and replaced them.the power on, problem has solved
    then the picture was change and the the color isn't correct
    don't know where to start and what's the problem?t con ,main board
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    Re: lg 42lb7rf "Reverse Colors" Problem
    Looks like a T-CON failure. If it had the AS15-F IC, I would even say that you just need to replace that one, but as far as I can see, that U5 doesn’t look an AS15.
    • saddle_au
      Waste Warrior
      • 121
      Best guess, my 2c worth, is first look at the signals on the LDVS cable on the TCON side. Sometimes the cable connector needs cleaning, reseating or padding. Check the fuse and the regulator voltage. Make sure the voltage coming in on the LDVS cable is right as well (+12v on pins 48 to 51).
      Also one or more of the drivers in the gamma chip on the left (the one surrounded by resisters top and bottom) might have failed and is pulling up all of the other outputs to give this color distortion. It may also be the regulator feeding the input resister chain.
      The board is an LC420WU6-SLA1 and seems to be available from a variety of places. The panel file LC420WU4-SLA1.pdf does not show the schematic of the board, just the connector layouts.
      I've swapped a lot of AS15 gamma chips on Samsung boards, and they can look like this when a driver has died. This is an LG/Philips panel but the gamma section works the same.
      • saddle_au
        Waste Warrior
        • 121
        But first,,,,,,
        The panel code might be wrong in the eeprom on the main board. Early Samsungs corrupt the eeprom contents with bad power supply cap hassles. I have seen this solarisation mentioned on the web before due to wrong eeprom parameters after a mainboard swap.
        https://www.youtube.com/watch?v=Q1bg9qP_qic
        https://www.youtube.com/watch?v=c-aXKCTiU6I
          • 12081
          • U.S.
          Originally posted by saddle_au
          But first,,,,,,
          I wonder if a firmware update might fix it?
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Xristakis795
            le32a436t1d samsung problem with gamma ic
            by Xristakis795
            hi
            i have the above model of tv and it has gamma problem distort color
            Tcon board is v315b1-c01
            so i used from samsung le32r86bd the tcon board its exactly tha same nd same inches 32'
            I have the following problem when changing the card
            the letters of the dialogues are hidden I can not see them
            I need to move the bottom of the image up and the top of the image down
            I have a problem with the vertical
            11-15-2021, 11:15 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
