le32a436t1d samsung problem with gamma ic
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi
    i have the above model of tv and it has gamma problem distort color
    Tcon board is v315b1-c01
    so i used from samsung le32r86bd the tcon board its exactly tha same nd same inches 32'
    I have the following problem when changing the card
    the letters of the dialogues are hidden I can not see them
    I need to move the bottom of the image up and the top of the image down
    I have a problem with the vertical
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Re: le32a436t1d samsung problem with gamma ic
    You will need to go into service mode perhaps and have a look if there is a setting that you can adjust to sort this issue out. I am not 100% sure. What i have wanted to do in the past when changing similar TCON's is to swap the eprom IC's to see if it sorts out the problem. Apparently there is software loaded in the TCON so i guess if you transfer the eprom to the other tcon it should work fine.
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      ιs there a possibility to do this from service mode?
      • cheeky2
        • Dec 2012
        • 337
        • uk
        You cannot read eeprom on the tcon board using the service menu.
        There are three options
        1. change as15f on original faulty board
        2. remove the eeprom from your original board and transfer to your working board
        3. read eeproms and clone the eeprom data onto the working board
        • THXFX
          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
          by THXFX
          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
          I check capacitors and diodes and didn't find any short IN MAINBOARD.
          Measured all power supply...
          03-20-2024, 03:21 AM
          09-07-2024, 05:50 AM
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
          09-06-2024, 11:40 PM
