Samsung LN46C60351FXZA No Picture
  • Serlynth
    • 6
    I have a Samsung LN46C60351FXZA that is about 4 years old. One morning I turned it on and it was working fine. About 10 minutes later, the screen went black, but the audio was still there. The TV powers on and the audio works. I can change the source of the tv and the audio stops until i change it back. There is just no picture. I have opened the TV up and all of the capacitors look fine. Any help would be great.
  • sordids999
    • May 2013
    • 2155
    Re: Samsung LN46C60351FXZA No Picture
    Pictures showing your tv parts may help you more with fixing your problem
    • capkid
      • Oct 2010
      • 1339
      Do you see a picture if you shine a flashlight at the screen? Also, are you sure you've correctly noted the model number?
      LG Plasma Mal-Discharge Correction Service
      • Serlynth
        • 6
        Yes, it is the correct model number. I dont see anything if i shine a flashlight at the screen. I will try to get a better flashlight to test it too.
        Pictures are attached. If needed i can take closer pictures of certain parts as directed.
          • 12206
          • U.S.
          can you tell if you get a menu at all?
          • Serlynth
            • 6
            I am assuming the menu shows up as I can change the source, volume, etc. it's just a black screen.
            • capkid
              • Oct 2010
              • 1339
              The model number is not the same as what you posted in the thread's title. This particular model is known for having PSU/inverter issues. I'd start by checking PSU output voltages. Also, I'll wait for a definitive response as to whether an image is visible when a flashlight is shined at the screen.
              • Serlynth
                • 6
                Sorry, it was a type, 5 instead of k!
                Also, should i be able to see anything with an iphone flash light, or will i need a heftier one? I will grab a multimeter from work when i go back on Monday.
                • capkid
                  • Oct 2010
                  • 1339
                  And the "0" and "3" were transposed Anyway, an iPhone light should be bright enough.
                  • Serlynth
                    • 6
                    Then no, i did not see anything on the screen with a flashlight.
                      • 12206
                      • U.S.
                      maybe check the fuse on tcon board.
                        09-07-2024, 05:50 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Dodgethis
                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                        by Dodgethis
                        Hello all,
                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                        09-11-2024, 07:39 AM
                      • YellowJacket
                        Samsung QE55Q60RAT - no picture
                        by YellowJacket
                        Hi friends,
                        a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                        07-30-2024, 01:31 PM
                      • Dobsuk
                        Samsung UE50TU8000K no picture or lanes on it
                        by Dobsuk
                        Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
                        And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
                        The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes...
                        04-25-2023, 07:34 AM
