Sony KDL-55HX820 5 red blinks
  • ntehicks
    • Mar 2011
    • 272
    I just Picked up this TV. I would really like to fix it. I turn it on and get 5 red blinks. I understand this error means T-Con but I was also told it could be a panel. I will take some pictures when I get the back off and post them as well.
  • ntehicks
    • Mar 2011
    • 272
    Re: Sony KDL-55HX820 5 red blinks
    Here are some pictures of the board.
      Check and see if you have 12VDC at both ends of the SMD fuse on the T-CON.
      • ntehicks
        • Mar 2011
        • 272
        would I test this while the tv is in standby or when it is in error blinking? I have found 4 fuses on the t-con. F8001 power in and F8002 out to Main Board. and then two smaller fuses on the board. I have tested continuity on all 4 fuses and they test good.
          Have the meter connected to the fuse and then hit the power switch to see if it did jump up to 12V for seconds and drops down.
          According the error code 5-blinks is not necessary the T-CON, it is labeled as Doubtful.
          • ntehicks
            • Mar 2011
            • 272
            I connect the meter to the fuse and it doesn't move. it switches so fast from green to red blinking. so I start with it in standby so the tv has a red led solid and then I turn the tv on and it blinks green for a half second and then red blinking.
              If you look at page 64, it is more likely no the T-CON.
              I cannot find the SCH for your power supply boards:
              Sony 1-474-305-11 (DPS-76, DPS-76(CH), 1-883-923-11) G7 Board
              Sony 1-474-330-11 (APS-299/C, APS-299/CW(CH)) G6 Power Supply Board
              http://www.shopjimmy.com/sony/kdl-55hx820/
              • anmol
                • Mar 2012
                • 73
                • India
                G6AW APS-299 - 1-883-922-11 - CXA3811M , CXA3799AM , MIP2H2
                Regard
                • ntehicks
                  • Mar 2011
                  • 272
                  I have ordered a Sony 1-474-305-11 (DPS-76, DPS-76(CH), 1-883-923-11) G7 Board. this is the board that the Sony service manual suggests replacing. I think I will check some of the parts on the old board and see if I can find a bad part.
                  • ntehicks
                    • Mar 2011
                    • 272
                    so the new board didn't make any difference. so I decided to go back to the troubleshooting diagram. I tested pin 1 at cn6001 that is suppose to be 12v and I only get 3.2. so it looks like something on the main G board. any ideas on what to test first?
                    • ntehicks
                      • Mar 2011
                      • 272
                      Ok so on CN6101 I test on pin 1 power on I am getting 3.4 vdc
                      on pin 10 stby I am getting 3.3 vdc and on all of the 12 volt pins I am getting 10.8vdc
                      I am thinking that I should have 12 volts to run the main board. when I press the power button the power on drops to 0.
                      • ntehicks
                        • Mar 2011
                        • 272
                        not sure if I am suppose to, But I am getting 390vdc on the main filter caps while in standby. I need some help to determine if I need to purchase power supply or mainboard?
                        • KDL55HX820
                          • Jan 2015
                          ntehicks,
                          Did you ever pinpoint the problem?
                          Thanks,
                          KDL55HX820
                          • ntehicks
                            • Mar 2011
                            • 272
                            no I haven't I think that I am not suppose to have 390volt on the main filter caps while the tv is in standby. I think it is a problem with either the main G6 power board or the BATL main board. I think I am suppose to hear a click when the tv turns on and I don't get that. I thought at first that it could be a panel. but I have disconnected the panel from the t-con and the tv still does the immediate shutdown and 5 blinks. I have searched for a new G6 board but having troubles finding the exact replacement. I might have to put this one aside and start on the 52" Samsung.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Remove the PS_ON wire from the connector and see, if do you still have that 390V on the capacitor.
                              • ntehicks
                                • Mar 2011
                                • 272
                                ok I removed the Power_on wire which is pin one on the power supply cn6101. Now when I plug in the tv the red light blinks 2 times instead of going solid (standby). The voltage on the main filter caps is 169. I have included pictures of this connector
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  The PS_ON state changes?
                                  • ntehicks
                                    • Mar 2011
                                    • 272
                                    it is almost like the tv PS_ON is stuck so when you plug in the tv even though it is in standby the supply has its full voltage on the hot side
                                    • ntehicks
                                      • Mar 2011
                                      • 272
                                      ok I ordered a new G6 Power board and tested. Darn still not working. I did pull out the trusty magnifying glass and took a look at the main board real close. I found on one of the HDMI connectors that there was a problem and on the inside of the connecter there was damage to the pins. I will order a main board and see if this will resolve all the issues.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I would make sure, that there is no short first, then measure again. Don't just jump and order boards.
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • GoodCapDude
                                          Sony XBR-75X940E intermittent 6 blinks error code
                                          by GoodCapDude
                                          Hi everyone. First post on Badcaps!
                                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                          09-20-2025, 06:07 AM
                                        • bbrain
                                          Sony KD-55AG9 TCON?
                                          by bbrain
                                          I have this problem with my Sony 55' AG9.
                                          It flashes 4x.
                                          I have found the service manual, and seems it is the TCON.
                                          Before I buy a TCON can someone check the vid?
                                          Thanks in advance!...
                                          09-19-2024, 10:50 AM
