Samsung PS51D550 no picture!
  • Tolmulest
    • 22
    • Eesti
    Hello!
    I have Samsung PS51D550 plasma tv.
    I had it without picture and i have replaced Y sus and Y buffer boards, because they were shorted.
    But i still have no screen, if i turn on the tv i see quick flash at the bottom of the screen and then VS, VA and VE starts dropping and stays at ~20v.
    If i Disconnect the ribbon cable between Y-Sustain and logic board VS,VA and VE stays at right voltages.
    Im really confused and i dont understand whats wrong, any ideas?
    Any help would be appreciated!
  • sordids999
    • May 2013
    • 2161
    Re: Samsung PS51D550 no picture!
    pictures of the boards may help you further to fix your problem
    • Tolmulest
      • 22
      • Eesti
      Boards marked with Blue crosses are changed with new working ones.
      Ribbon cable with red cross is buffer and y-sustain cable if its connected then VS, VA, VE will drop! If disconnected VS, VA, VE will remain normal.
      If you need pictures of every board single i will make them!
      And thanks for answering!
      • mmartell
        • Oct 2013
        • 3189
        First, are you CERTAIN the replacement boards are working boards or you were just told that ? If the boards ARE good then you could have a faulty control board. Have you checked the zsus for shorts ?
        • Tolmulest
          • 22
          • Eesti
          Yep im pretty sure that replacment boards are working. How to i check the z sus for shorts? I checked Y-sus with multimeter between VS and ground and i got resistance so the Y sus was shorted(Measured the new board with same technique didnt get resistance). I used the same method with Z sus and didnt get resistance. Should i check something more? And buffer board had one chip shorted to ground. New one doesnt! Did like it in this video to check for shorts https://www.youtube.com/watch?v=51SZsfH60EY
          • Shinju
            • Mar 2014
            • 1239
            Check for small/micro cracks in the corners, I think these 550 series are known for bad glass and cracking.
            Disconnect your ZSus and power on the unit and see if you get the Samsung chime on power up.
            Are you getting any chime when you disconnect the y-main ribbon and power on the unit?
            • mmartell
              • Oct 2013
              • 3189
              Originally posted by Tolmulest
              Yep im pretty sure that replacment boards are working... I checked Y-sus with multimeter between VS and ground and i got resistance so the Y sus was shorted(Measured the new board with same technique didnt get resistance). I used the same method with Z sus and didnt get resistance.
              This is backwards. If you get no resistance then you have a short. Where did the boards come from ?
              • Tolmulest
                • 22
                • Eesti
                Shinju: What cracks? On the corners of the screen? If so i have checked it already and havent find anything unusual.
                What do you mean by samsung chime?
                mmartell: i ordered them from Trusted ebay sellers.
                • capkid
                  • Oct 2010
                  • 1339
                  Like a lot of these Samsungs, I'd check the components on the Y-main and X-main heat sinks for shorts. The X-main and Y-main can kill each other if either is bad.
                  Samsung startup melody: http://youtu.be/ogONgEQySTc
                  LG Plasma Mal-Discharge Correction Service
                  • mmartell
                    • Oct 2013
                    • 3189
                    The melody can be disabled in the menu so cannot be counted on to chime if the PO disabled it.
                    • Shinju
                      • Mar 2014
                      • 1239
                      True, but I have yet to come across a Sammy that had the audible chime turned off!
                      • mmartell
                        • Oct 2013
                        • 3189
                        My personal sammie has it disabled but you may be right about most others.
                        • capkid
                          • Oct 2010
                          • 1339
                          This is a slightly different model, but the tips should be applicable to your TV: http://youtu.be/-7zWKY2Hwnc
                            All but one of mine had it turned off... The one which had it was very useful in the diagnosis process.
                            • Shinju
                              • Mar 2014
                              • 1239
                              I have been pretty fortunate on all the Samsung panels I have gotten only 4 of them out of 30 or more have been a total loss.
                              I always tell the people I sell em too or give them too to leave that chime on in case of any failure that might cause the screen to not display a picturenit helps the tech/me diagnose things a little easier.
                              Nothing like like calming your nerves when you hear that annoying chime sound off when you repair a sammy!
                              • Tolmulest
                                • 22
                                • Eesti
                                No chime maybe its disabled.
                                Any tips how to check xmain shorts?
                                  Check Vs and GND on X-main using 2000 ohm range, do this with power off and unplugged.
                                  • Tolmulest
                                    • 22
                                    • Eesti
                                    No resistance between VS and ground.
                                    • Tolmulest
                                      • 22
                                      • Eesti
                                      Also the board is removed from tv
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        There you go then.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
