lg 42PX4DV-EA switches on then off
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Hey guys I've found myself a plasma and so far I'm not a fan!
    This one clicks on the light goes from red to amber to green and then clicks off and back to red. Caps all appear ok from a visual inspection. Also once its put itself back in standby if I attempt to turn it back on again the light will turn amber but theres no clicks from the power supply and the light doesn't go green I have to disconnect power for a short peroid before the supply will click again.
    I have no clue other than some thing else on the power supply is bad, any ideas?
    • 12322
    • U.S.
    Re: lg 42PX4DV-EA switches on then off
    havent liked plasmas since I tore 1 apart, panny, with 2 loud fans and a whole lot of parts to deal with, no tab bond issues tho.
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      I think this is the second one ive taken a peek inside of, theres just so much more to them and they weigh a tonne. Make no wonder they're discontinued lol
        • 12322
        • U.S.
        could still be a cap, they dont have to bulge to be bad.
          • 12322
          • U.S.
          try to grab a manual if you want to troubleshoot, should be one in the stickie posts at the top of the list.
          • quiggy
            • Aug 2014
            • 136
            • United Kingdom
            Yeah ill take a peek, just didny want to be ripping random caps out incase anyone else knew what it was before hand
              • 12322
              • U.S.
              good idea.
              • quiggy
                • Aug 2014
                • 136
                • United Kingdom
                Found a service manual but can't view it.on my phone so need to wait until I get home
                • quiggy
                  • Aug 2014
                  • 136
                  • United Kingdom
                  I think I'm making progress, with the zsus board disconnected the power supply doesn't click back off it stays on
                    • 12322
                    • U.S.
                    can you post some good clear pics. of the boards and maybe one of how their all connected?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Probably zsus or the buffers at fault then, could you take pics of the boards please.
                      • quiggy
                        • Aug 2014
                        • 136
                        • United Kingdom
                        Yeah I'll get some pics sorted out as soon as I can
                        • quiggy
                          • Aug 2014
                          • 136
                          • United Kingdom
                          I can take more/better pics if needed just let me know
                          • quiggy
                            • Aug 2014
                            • 136
                            • United Kingdom
                            Also the fuse near the capacitors on the zboard, when thats taken out the psu remains on as well.
                            • quiggy
                              • Aug 2014
                              • 136
                              • United Kingdom
                              Are the pictures sufficient ?
                              • GRANDGG
                                LG 42lw4500 flashing red light , wight light , 2 clicks
                                by GRANDGG
                                Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                05-09-2025, 12:27 PM
                              • huzo
                                HP 470 G5 blinking amber light no power
                                by huzo
                                The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                I've tried flashing the bios...
                                interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                06-08-2023, 04:08 PM
                              • stevenallauca
                                HP laptop does not charge the battery, the light turns amber and then changes to white.
                                by stevenallauca
                                Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                - ACN (BQACN) 19.6v
                                - ACP (BQACP) 19.6v
                                - CMSRC (BQCMSRC) 19.6v
                                - ACDRV...
                                09-23-2024, 11:30 AM
                              • zwect
                                Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                by zwect
                                I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                Here is the original BIOS dump from the 25R256JVEN chip.
                                09-11-2024, 05:54 PM
                              • Noah Glasse
                                LG 50PK590 - three clicks and steady red light, won't turn on.
                                by Noah Glasse
                                I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                02-24-2025, 07:23 AM
