Samsung LN-S4095D - Won't turn on; Power LED 5 blinks - I think I see a problem
  • AFajitas
    • 183
    I acquired this TV today and noticed that the top plastic casing was melted at one point right above the T-CON board from what I can only assume is overheating.
    I did a quick inspection of the tops of the boards and everything else appears okay at first glance.
    Anyone have any idea what caused this or can point me in the right direction for troubleshooting? I've got a DMM but I'm not very familiar with troubleshooting component level electronics. I've also got a decent soldering setup.
    Images Here
    Quick handheld shots as I am hanging out with my kids, I will take better ones later once they go to sleep.
    Any advice or guidance would be greatly appreciated.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung LN-S4095D - Won't turn on; Power LED 5 blinks - I think I see a problem
    Wow at first glance I would say that thing at a lack of cooling it might have been stuck underneath the area that didn't allow it to vent
    • R_J
      • 9515
      Its possible someone placed something on top of the set (like a blanket or coat) preventing proper ventilation. You did'nt say if the tv is working. if the tv works I would not worry about it.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4913
        • New Zealand
        That would have had to get pretty damn hot to do that! Over 170°C surely
        -David VanHorn
        • AFajitas
          • 183
          It doesnt turn on. It clicks and the power led blinks 5 times when i plug it in. It is unresponsive after that unless i unplug and plug back in.
            • 12081
            • U.S.
            time to troubleshoot, try to upload some good clear pics. of the tv, of all the boards and clear pics. of each board, careful when working with power supply board HIGH VOLTAGE. ok, strike that, I see the pics.
            • CapLeaker
              Leaking Member
              • 7985
              I guess it is time to measure voltages! Is the back light coming up?
              • AFajitas
                • 183
                no back light. Is there a guide you guys can point me to that will show me where to measure the voltages and what they should be? I did check two of the fuses on the power supply and they checked out good. I also know to be very careful around the large capacitors on the power supply board. Should I get a resistor so that I can drain them safely?
                  • 12081
                  • U.S.
                  maybe try unplug bl-on from power supply to main board, should be labeled on the board by the connector cable, see if the back lights come on.
                  • AFajitas
                    • 183
                    Im assuming this is the backlight control cable? I removed it and no backlight. Tv still clicked when i plugged in and power led blink 5x. I noticed these 2 LED are illuminated on the mainboard when plugged in. please see attached photo
                      • 12081
                      • U.S.
                      hard for me to tell from the pic., backlight on is labeled on some power boards as bl-on.
                      • CapLeaker
                        Leaking Member
                        • 7985
                        that's why we need good pictures from the whole board you have trouble with. maybe you can take another one with the pin outs
                          • 12081
                          • U.S.
                          I thought that looked like a pretty small board.
                          • AFajitas
                            • 183
                            I dont know which board I am having a problem w/. I'm looking for guidance on how to find out which board(s) have issues. I have provided pictures of all the boards except for the inverter in my original post.
                            • AFajitas
                              • 183
                              here is the side that I unplugged from the power supply board that I suspect is backlight on.
                                • 12081
                                • U.S.
                                thats the problem, we have no way of knowing that this is a different post, theres 100s of posts, the only pic. we see is the one with 25 percent of the board.
                                • AFajitas
                                  • 183
                                  Ok, apologies. Let me try this again. Samsung LN-S4095D, loud click when TV is plugged in, follow by five blinks from power button LED. Top vent on plastic frame was melted near the TCON board.
                                  I have a multimeter but I need some help figuring out where to measure. No blown or bulging caps as far as I can tell.
                                  • CapLeaker
                                    Leaking Member
                                    • 7985
                                    Start on the power supply. There is a 26 pin header on the top right of the power supply board. Plug everything back together and test that header with your DMM. The pin outs for it is marked between the 2 transformers and the big aluminum heat sink. Put the negative lead to GND and probe all others. Note the voltages down with the pin numbers and post back.
                                    Don't touch the hot side of the power supply, just that header.
                                    • AFajitas
                                      • 183
                                      While the set is plugged into power, right?
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4913
                                        • New Zealand
                                        Yes, you can't measure voltages if the thing is turned off\unplugged. Just be careful to avoid the primary side where the mains comes in, and watch the heatsinks too, they are usually grounded but not always.
                                        http://www.repairfaq.org/sam/tvfaq.htm#tvsaf It's about CRTs but the high-voltage\mains safety points still apply.
                                        -David VanHorn
                                          09-07-2024, 05:50 AM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
