Re: samsung LN-S4051D diagnal lines
Well that DS805 (1N4937) is the snubber Diode for the Relay REL801, it is connected in parallel with the relay coil (Omron G5RL 5vdc COIL, about 62 Ohm DCR) that is why it show conduction in both direction, that is why I ask you to take the RESISTANCE reading of the Diode, not in the Diode mode, I get some idea what the resistance is.
When you check semiconductor for shorts, leakage resistance, you use Ohm mode because when semiconductor shorted out it will no longer act as semiconductor.
you can use 1N 4007 in its place. You can verify by check the resistance of the two copper pads where the diode's legs are connected to and see what resistance you get.
BTW, if the power supply is bad it will affect not just the pictures but also other circuits as well.
It is not mega pixel, it is the lights and the MACRO, and tripod or very steady hands, I use my over 10 years old SONY with good MACRO mode and <2M pixel.
https://www.badcaps.net/forum/showth...ight=dell+2007Last edited by budm; 01-01-2015, 06:17 PM.Leave a comment:
http://assets.shopjimmy.com/media/ca...bn4400134a.jpg ds805 read .058 in both directions, ds804 read .344, I think they are suppose to be .4 to .7?Leave a comment:
http://assets.shopjimmy.com/media/ca...bn4400134a.jpg ds805 read .058 in both directions, ds804 read .344, I think they are suppose to be .4 to .7?Last edited by nomoresonys; 01-01-2015, 08:17 AM.Leave a comment:
i ll try to get a good pic of power supply.Leave a comment:
Which one of these is you board?
http://www.shopjimmy.com/samsung-bn9...ain-board.htm#
http://www.shopjimmy.com/samsung-bn9...main-board.htm
Does your board have this cap?Leave a comment:
That model tv is known for bad panels. I would change the caps,and diodes to see if any thing changes.Leave a comment:
trying to locate a training manual, no luck yet.Leave a comment:
do you think a bad diode would make that snowy horizontal like picture?Leave a comment:
woah, just looked at those pics. again, theyre terrible, gotta get a better camera.Leave a comment:
theres numbers on the tiny diode, I couldnt match them up on digikey, pretty sure its a power/rectifier diode, black with the grey band, numbers on it are v8180, n493, gp, Thanks for helping, not getting too far with this one.Leave a comment:
hi splitcrete, I dont have an esr meter to check caps, checked diodes,801,2,3, checked ok in cir., 804 was .344, 805 was .058 in both directions, tried to take it out to measure out of cir. but it broke, or is there a way to measure caps with the mm.Last edited by nomoresonys; 12-31-2014, 04:32 PM.Leave a comment:
Check caps cm 807,808,809,811,812,817,cs806
Check diodes ds801,802,803
You just may find a couple of them bad.Leave a comment:
got bad reading from diode ds805 read in board .058 in both directions, tried to take it out to read it but broke it, no solder skillz at all lol, also diode ds804 read .344 is that too low?, hard to read numbers on tiny diode , looks like GP v8180 n493 or n498?, does that sound like a familiar diode, I messed up label a bit getting it out, Thanks.Last edited by nomoresonys; 12-31-2014, 04:24 PM.Leave a comment:
What do get using Ohm mode to check the Diode?
Location of that Diode?"Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
