Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
Re: Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
not sure if thisis correct or not, was out of 50x20b
While pressing [VOLUME ( - )] button of the main unit, press [0] button of the remote control three times within 2 seconds.Comment
that picture of the SC board you uploaded, is that the one currently installed?
If so , can we get a sharper picture si I can see the components and soldering up close.
Looks like a repaired board and one of the coils looks like it's bentComment
I have a basic LCD digital scope if that helps.They aren't chained on this model. It looks exactly like dodgy SC so can only think of one other possibility and that's bad signals to SC (or possibly SS but seems less likely)
Hard to tell without a 'scope on the outputs, can only do some basic volt checking.
I can't see bad SU/SD causing this.
I have tried 2 SC board swaps - both of which were tested in a working TV before shipping to me, so I think it is unlikely to be the SC.Comment
Got a picture of the basic scope? It may be usable...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The SC board was actually from a slightly different model of TV. The first part of the part number was the same, but the subsequent 2 letters were different - and although it looked identical, it apparently was not. Inserting the correct SC board has resolved the issue.Comment
Cant remember now - but the last 2 letters of the part number that are often not quoted do denote a different part! I found it on eBay UK.Comment
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo - Loading...
