Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
  • richto
    • Feb 2015
    • 11
    Re: Panasonic TC-P46ST30 Fixed SC Board But Still Have a Display Issue
    Originally posted by tw2005
    have we tried flicking through all the test patterns in serv mode yet just in case this is A board? Is the Sc20 ribbon ok at both ends, not damaged or corroded? A removed sc20 ribbon will trigger 8 blinks and you said it was intermittent shutdown of 8 blink then just fixed itself?
    I would not have expected sc would take out ss either.
    No - how do I look at the test patterns?
    Ribbon cable seems ok. I re-seated it to fix the 8 blinks.
    • tw2005
      • Oct 2011
      • 6458
      not sure if thisis correct or not, was out of 50x20b
      While pressing [VOLUME ( - )] button of the main unit, press [0] button of the remote control three times within 2 seconds.
      • tw2005
        • Oct 2011
        • 6458
        if not try
        While pressing [VOLUME ( - )] button of the main unit, press [INFO] button of the remote control three times within 2 seconds
        • tw2005
          • Oct 2011
          • 6458
          that's to get into service mode, then you push 1 on remote to scroll through until aging comes up, then ok, then 3 to scroll through the different patterns
          • tw2005
            • Oct 2011
            • 6458
            that picture of the SC board you uploaded, is that the one currently installed?
            If so , can we get a sharper picture si I can see the components and soldering up close.
            Looks like a repaired board and one of the coils looks like it's bent
            • richto
              • Feb 2015
              • 11
              Originally posted by tom66
              They aren't chained on this model. It looks exactly like dodgy SC so can only think of one other possibility and that's bad signals to SC (or possibly SS but seems less likely)
              Hard to tell without a 'scope on the outputs, can only do some basic volt checking.
              I can't see bad SU/SD causing this.
              I have a basic LCD digital scope if that helps.
              I have tried 2 SC board swaps - both of which were tested in a working TV before shipping to me, so I think it is unlikely to be the SC.
                Got a picture of the basic scope? It may be usable...
                • richto
                  • Feb 2015
                  • 11
                  The SC board was actually from a slightly different model of TV. The first part of the part number was the same, but the subsequent 2 letters were different - and although it looked identical, it apparently was not. Inserting the correct SC board has resolved the issue.
                  • aharben
                    • Jun 2015
                    Curious what p/n SC was correct and where did you find it in stock?
                    • richto
                      • Feb 2015
                      • 11
                      Cant remember now - but the last 2 letters of the part number that are often not quoted do denote a different part! I found it on eBay UK.
