Samsung LN46A550P3FXZA Squealing, clicking on and off
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung LN46A550P3FXZA Squealing, clicking on and off
    I still have a C series, that just clicks on and off endlessly, it can't be something similar, with that board also?
      You can look and see if it uses the same ICS, then use your scope to look at the ripple voltage on those TOKIN caps.
        I replaced C102 (47uF 10V TONKIN NE AS7) cap in my LN32A550P3FXA and so far it is not squealing and starts up fine, I am going to let it run all night to see if that fixed it for sure.
        I will work on the LN37A550P3FXVA and LN46A550P3FXA next to see if it will fix the same problem too.
        It will be great to get all 3 fixed tonight!
        • Shinju
          • Mar 2014
          • 1239
          Awesome! Glad it was a simple fix! Might have to look at mine again!
            Could not have done with the help from SHOPJIMMY website.
            I also replaced C131 which on the top side of the board and it is the exact same type of cap so if one went bad, another one may go out too.
            • tibimakai
              • Jan 2012
              • 3680
              How it should look like a good and bad one?
                The peak to peak should be in mV range, it will be high frequency ripple.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Should I measure at the input connector(from the PS), or just at these regulators?
                    You will measure the waveform on the two legs of the filter cap (the NE AS7 cap). Does it use the same cap and IC as used in the A series?
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      #30
                      Bud,
                      If you don't mind me asking, where did you get the replacement capacitors for C102 and the one on the top of the board as well? I have several of these boards with both the squealing and/or rebooting problem but cannot seem to locate a source for those capacitors.
                      Thanks,
                      Aaron
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        #31
                        Scratch that request. Found some at Mouser. Digikey was out of stock.
                        Thanks regardless,
                        Aaron
                          I get KEMET polymer from MOUSER.
                          I was able to fixed all 3 model, the 32, 37, and the 46 A550P3 series last week and still burning them in.
                          • aaronwt6
                            • Apr 2013
                            • 855
                            • US
                            #33
                            Thanks bud. I found a link to the Panasonic equivalent in another thread at digikey. Although they were out of stock, that gave me a part number to search for which lead me to mouser. I've never ordered from them but know they are a reputable source. Hopefully the come quick so I can give these a shot. Seems there is quite a number of models that use that same board layout.
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              #34
                              Oh, and the customer's that I have on the bench right now is a PN50A500 plasma.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Since you already did the search, could you please post here the link, for that part?
                                  Either one of these two for NEC-TOKIN caps.
                                  You can temporary solder 100uF 10V low ESR in parallel with the C102 to see if it will solve the problem, mines did.
                                  • chopdre
                                    • Jul 2012
                                    • 8
                                    • barbados
                                    #37
                                    Good day, anyone have this board for sale?
                                    Samsung LN46A550P3FXZA main board
                                    thanks.
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      #38
                                      Same/similar fault occurs with the Samsung 'Bordeaux' mainboard (Gawd knows the board number!)--But its the two surface-mount 1000uF 10V caps under the tin-work near the main processor....
                                      Seen 3 in recent weeks....
                                      TELEFIX
                                      • tarner
                                        • Aug 2015
                                        I had an issue with this TV not turning on it would just play the boot tone and stop.
                                        I replaced C102 and C131 with 60V 47uf caps (All I had on hand).
                                        The TV now boots up but i get moving lines only on the top portion of display.
                                        They will go away when moving the bezel but will come back shortly after.
                                        Occasionally it will stop once warmed up 10-15 minutes.
                                        Any idea's would be appreciated.
                                        • alexwitter
                                          • Feb 2016
                                          Awesome!
                                          LN46A550P3FXZA
                                          BN41-00975B (BN96-08988A)
                                          Same squealing/screeching audio, power cycling with torn frozen green/blue/red pixelated video. Has been degrading more and more over the last month (would cycle itself 10+ times)
                                          Used a 100uF 16v Cap
                                          Ran in parallel with C102 - 47uf 10V (NEr AS7)
                                          Works great (See image below).
                                          Now, how long will this hold out for?
                                          should I remove the bad C102?
                                          Can I safely run this until a replacement cap arrives (with or without C102)?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
