Phillips 42OFL3704D/F7
  • barryra
    • Aug 2013
    • 107
    When power button us pressed.. I hear a click & front indicator light turns white but has no picture or backlight.
    Any ideas?
  • barryra
    • Aug 2013
    • 107
    Re: Phillips 42OFL3704D/F7
    Subject Should be 42PFL3704D/F7
    Any ideas?[/QUOTE]
    • barryra
      • Aug 2013
      • 107
      bump.....
      • barryra
        • Aug 2013
        • 107
        Bump... thanks for any info.
          https://www.badcaps.net/forum/showthread.php?t=39740
          There are more than one version of this model.
          http://www.shopjimmy.com/catalogsear...2PFL3704D%2FF7
            • 12274
            • U.S.
            try to post some pics., of your boards, I'd start with checking the fuse on the power supply board, careful power supply has high voltage.
            • barryra
              • Aug 2013
              • 107
              Thanks for the replies. I attached a picture & hope it tells you a idea what may be wrong.
              • barryra
                • Aug 2013
                • 107
                I thought I better post clearer pictures.
                • barryra
                  • Aug 2013
                  • 107
                  Did the pictures give any ideas what the issue may be? Thanks
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Do you have a digital multi-meter?
                    • barryra
                      • Aug 2013
                      • 107
                      Hi... yes I do...
                      • barryra
                        • Aug 2013
                        • 107
                        bump...
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          There doesn't look to be much info on this set. If your power supply has labels at the connectors for the expected voltage, I would prove each pin at each connector to look for that expected voltage. Personally, I suspect your main board, without knowing what the expected voltages on each pin are, I can't really help you with any guidance.
                            Please upload the pictures of the whole back side of the TV so I can see all the boards.
                            Check to see if you do have 24Vdc on any one of the red wires (black probe on the chassis) on the white connectors which should go to the inverter board.
                            https://www.badcaps.net/forum/attach...0&d=1418779596
                              • 12274
                              • U.S.
                              try to grab a manual, if the power supply board isn't labeled with expected voltages where connectors go, if the voltages are correct, then power supply is prob. good.
                                • 12274
                                • U.S.
                                my phillips had blown capacitors on inverter board.
                                  BTW, is the TV actually is 42PFL3704D/F7, not Phillips 42OFL3704D/F7.
                                  Service manual for 42PFL3704D/F7
                                    • 12274
                                    • U.S.
                                    Any ideas?
                                    [/QUOTE] yes
                                    42PFL3704D/F7, typo in title.
                                    • michaelbodine
                                      • Aug 2018
                                      Did anyone ever figure out what this issue was? I have the same TV with the same problem.
                                      I checked all the voltage going from the inverter board to other boards, all seem to be correct.
                                      • michaelbodine
                                        • Aug 2018
                                        To elaborate a bit more, when I plug in the TV or turn it on, after about 7 seconds there is a brief flicker on the front of the TV then it all goes dark.
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
                                        • IAmSad2
                                          GA-990FXA-UD3 Mainboard won't POST
                                          by IAmSad2
                                          Hi.
                                          Some weeks ago, my beloved 10 years old PC went belly up
                                          When I press the power button, the video card cooler start spinning, but I hear no POST beep and I see no image on the screen.
                                          The CPU gets mildly warm, but it might overheat if let running more than a few minutes without radiator, so I let the radiator on it (no fan).
                                          There is no chip overheating - I "fingered" all of them , I looked also through a cheap thermal camera.
                                          Not a single LED lights up.
                                          Power supply
                                          I measured the power on all pins. It is all...
                                          02-27-2023, 02:26 AM
                                        • liquidzorch
                                          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                          by liquidzorch
                                          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                          10-18-2024, 05:19 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • Stefan Steff
                                          HP Elitebook 840 G5 strange behaviour, need ideas...
                                          by Stefan Steff
                                          I finished my work for this year, so I'm free until January 6th.
                                          My last task it's unresolved and I'm looking for ideas for the return in January.
                                          So what's about...
                                          This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                                          My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                                          No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                                          The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                                          12-24-2024, 05:50 AM
