Sony KDL40W4000 with irregular green/red lines/haze
  • joonak
    • 3
    • Finland
    Maybe bad T-con / gamma chip?
    Re: Sony KDL40W4000 with irregular green/red lines/haze
    Check the LVDS cable is fully seated on both ends.
    • mmartell
      • Oct 2013
      • 3189
      Interesting as the distortions seems to follow gradation patterns. Report back please.
      • joonak
        • 3
        • Finland
        Forgot to say that the problem is not always there, it comes and goes
        • arctor
          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
          by arctor
          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
          04-26-2025, 05:22 AM
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • Chrissygizmo
          Sony KD-55XG9505 lines on screen problem
          by Chrissygizmo
          Hello again everyone,
          This is my latest mission, to try getting this Sony tv back to normal working order…
          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
          02-19-2025, 11:31 AM
