AKAI model# LCT42Z5TAP screen going R G B and white
  • erskine
    • Jan 2014
    • 20
    • barbados
    hi all ,
    I am repairing this akai lcd that came in with no power .
    I replaced some 220mf caps on the main board and got it
    to power up.
    Now its just comes on with a red screen and it goes blue then green and then .
    white . and repeats that cycle over and over.
    anyone knows what causes this problem?
    thanks
  • mmartell
    • Oct 2013
    • 3189
    Re: AKAI model# LCT42Z5TAP screen going R G B and white
    Test patterns ? Try to find out how to do a factory reset maybe.
    • erskine
      • Jan 2014
      • 20
      • barbados
      will try to find out how to factory reset it
      • nomoresonys
        • 12276
        • U.S.
        Originally posted by erskine
        hi all ,
        to power up.
        thanks
        have a sony KDL-46S4100 with exact same problem, saw where a few people fixed with another a board, didn't seem to work for me, unless I got 2 bad ones.
        • erskine
          • Jan 2014
          • 20
          • barbados
          well i cant even find the info to fatory reset the thing .
          seem unusual , but i downloaded the service manual . so will try
          fixing it without replacing any boards.
          • nomoresonys
            • 12276
            • U.S.
            same here, would like to try factory reset but don't know if I can with it in this state?
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
            • hcinne
              Dell G15 ryzen edition black screen 2 amber 1 white
              by hcinne
              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
              07-23-2024, 07:56 AM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
