Panasonic TCP-42S2 6blink
  • bikerbuddy
    • Jun 2011
    • 134
    Re: Panasonic TCP-42S2 6blink
    Every think ok now because SC and SS stay on,green light
    • tw2005
      • Oct 2011
      • 6458
      I see the pic, so yeah that's correct part. does anything in that photo I posted help at all? I'd be intersted in some resistance readings, P15v,P5v, IC771, and across those 5 pin pnp/npn transistors. I've marked it out best I could. Did you get any extra parts to allow for a few attempts?
      • tw2005
        • Oct 2011
        • 6458
        hang on, you confuse me, shorted parts and it's working or you just replaced those again and all good??
        • bikerbuddy
          • Jun 2011
          • 134
          If I connect back the A board TV shut down with 6 blink , I removed the two Buffer cable and connect back SC20 , power up and still shut down with 6 blink so what is your input on the a board .
          • bikerbuddy
            • Jun 2011
            • 134
            Yes I read some of your post and there is where I went and look for the 5 leg npn pnp , and yes as u mention D451 was shorted again.
            • tw2005
              • Oct 2011
              • 6458
              If I connect the back the A board TV shut down with 6 blink , I removed the two Buffer cable and connect back SC20 , power up and still shut down with 6 blink so what is your input on the a board .
              I don't want to jump to the A board yet, still trying to work out how the TV fired up with no SC20 lead connected but everything else was and no blinks, sc and ss energised? that's weird. if sc20 was removed it should have gone 6 blink that's part of the built in shutdown features.
              I'll have a look at the schematics for the A board but this is a new one for me.
              • bikerbuddy
                • Jun 2011
                • 134
                I do not mean that the tv power up with bright screen ,I meant thet the tv stay on no blink red light on and SC and SS board with green light
                sorry for the miss understanding.
                • tw2005
                  • Oct 2011
                  • 6458
                  The signal goes pretty much direct to IC9004, not much you can do there except replace that IC which you may have to go OEM. Still makes no sense to me though. If that Ic was defective and creating a false detect then I'd expect it to trip with SC20 / A20 removed
                  • bikerbuddy
                    • Jun 2011
                    • 134
                    TW2005 Previously the tv power up for a few seconds then start 6 blink and green light on SC and SS will die slowly , after repairing the SC board now the tv power up and stay on red light no blink and the Sc and SS light green does not die but if i connect sc20 tv start 6 blink
                    • tw2005
                      • Oct 2011
                      • 6458
                      And all that's with Sc20 removed? there's nothing else been removed say anything to do with the C buffers?
                      If you're certain the Sc is good, you could earth out the SOS6 line and that will bypass the sos6 trigger, is risky. If there is anything wrong with the Sc it will blow and I have done this for a 7 blink with no issue however I had 2 x 5081 boards I repaired with issues - 6 blink - the first fired up with bad image but nothing blew, turned out I had a lot of residue under IC521 the somehow was slightly conductive, the other, forget to replace D451, it fired up bad image, then a lot of smoke and burnt board and fused some of the tracks. Not my smartest moment.
                      • bikerbuddy
                        • Jun 2011
                        • 134
                        I am looking at the Protection circuit block diagram and it is indicating that SOS6 blink and is pointing at IC9003
                        • tw2005
                          • Oct 2011
                          • 6458
                          [QUOTE=bikerbuddy;510148]TW2005 Previously the tv power up for a few seconds then start 6 blink and green light on SC and SS will die slowly ,- understood
                          after repairing the SC board now the tv power up and stay on red light no blink and the Sc and SS light green does not die but if i connect sc20 tv start 6 blink - If I try this on mine I get 6 blink straight away, the LEDs on both SC and SS will give the impression they are staying on but thats because the cct is hold charge and they take a while to bleed off. How long did you watch them fully lit? This is really weird condition you have, not sure If i'm going to work it out for you[/QUOTE.]
                          • tw2005
                            • Oct 2011
                            • 6458
                            enters IC9004 first? then to IC9003
                            • bikerbuddy
                              • Jun 2011
                              • 134
                              tw 2005 I will do some voltage test later on all the tp on the sc board just to be sure all my voltage are ok , and we can pick it up another day
                              mean while thanks for all your help.
                              • bikerbuddy
                                • Jun 2011
                                • 134
                                Missed your last post, the lights on the Sc & SS stay on as long as the tv is on.
                                  To check if SOS6 circuit is bad, check voltage across blue poly caps, near ERC IGBTs.
                                  If operating correctly, should be between 40% and 60% of Vsus (about 200V, so between 80 and 120V)
                                  If you bypass SOS6 you could well have blown sus IGBTs after a few seconds, the ER circuit is there to reduce the stress on them, without it they end up driving the panel themselves, can be bad. On some sets it will just cause image distortion but on other sets it will blow parts up.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Missed your last post the, lights stay on as long as the tv is on
                                    yeah, I'm flying out today but should get online at some point. been waiting a couple od days tosee where you got, definitely not the result I was expecting. I'm sure tom will be intrigued. I'll check out a training guide and see if that gives a clue but maybe check the levels on pin 28 and pin 5 on IC9004 with sc20 removed and then again with it connected.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      guide
                                      from that some suggestions they make
                                      An increase or reduction of the Energy Recovery Circuit output (MID).
                                      Open connection between connector A20 on the A board and SC20 on the SC board. this is what should happen with sc20 removed
                                      Open connection between any of the ribbon cables on the C boards and the A board.
                                      Open connection between the ribbon cable/cables interconnecting the C boards. Wrong diagnostic by the A board.
                                      Maybe it's a straight through signal through IC9004
                                      6 Blinks SOS: Pin 65 of the CPU IC9003 monitors the status of the SC board. During normal operation, a low is applied to pin 65. If the SC board becomes defective, a high is provided to pin 65. As a result, the unit shuts down and the power LED blinks 6 times.
                                      The TC-P42X2/C2 series have an energy recovery circuit in the SN boards. This circuit monitors the scan board output and the sustain board output. Any abnormality on this circuit will trigger the 6 blinks code. If SC20 is disconnected or is not seated properly, the TV shuts down with 6 blinks.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        "The voltage from SC20 is connected to pin 65 the Panel CPU (IC9003) in the A board via the DC level shifter section of the multi-functions IC (IC9400).
                                        When pin 65 of the panel CPU (IC9003) goes high, the TV shuts down and the power LED blinks 6 times."
                                        slide 64
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          slide 66
                                          Verify that all the cables on the SC board are properly seated. Also check the ribbon cables and connectors on the A and C boards. Unplug the TV and disconnect connector SC20 on the SC board and connector C10 on the C1 board. Plug in the TV and turn it on
                                          Did the number of blinks change to 8 blinks?
                                          yes - SC
                                          no-Are there 15V and 5V at the SC board. (See the previous page for test points location)
                                          yes - A board
                                          no- Check connections between the P and SC boards. If ok, replace the P board
                                          • SuperAman
                                            PS5 HDMI port diode reading?
                                            by SuperAman
                                            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                            02-03-2024, 10:16 PM
                                          • abajor
                                            A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
                                            by abajor
                                            Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
                                            PPBUS_3GH diode: measures good .45V
                                            PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
                                            The weird so far is
                                            PP3v3_G3H_RTC_X diode: .104V (WTF?)
                                            PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
                                            Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
                                            Not sure what any of this means...
                                            03-18-2025, 10:27 PM
                                          • iMuhtaseb
                                            A2681 Keyboard, trackpad and sleep?!
                                            by iMuhtaseb
                                            Wow it's been a while since I posted!
                                            This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                                            A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                                            It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                                            Tested another locked logic board on customer's top case and it posted with keyboard and...
                                            05-22-2025, 09:59 AM
                                          • karoliens
                                            820-01700 PPVCC_S0_CPU normal resistance to ground/diode reading?
                                            by karoliens
                                            I am working on this board that has some water damage though not around this rail but I measured it anyway to rule out that CPU is not fried.
                                            Resistance to ground on PPVCC_S0_CPU rail is 2Ohm and in diode mode it shows 0V.
                                            What is the normal reading on that rail?
                                            TIA
                                            09-11-2022, 12:55 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
