820-01700 PPVCC_S0_CPU normal resistance to ground/diode reading?
  • karoliens
    • 18
    • Denmark
    I am working on this board that has some water damage though not around this rail but I measured it anyway to rule out that CPU is not fried.
    Resistance to ground on PPVCC_S0_CPU rail is 2Ohm and in diode mode it shows 0V.
    What is the normal reading on that rail?
    TIA
  • mon2
    • 14677
    Re: 820-01700 PPVCC_S0_CPU normal resistance to ground/diode reading?
    I think you may be ok here at 2 ohms. We had an a1398 with 1 ohm to ground and it was working fine.
    Also review this thread:
    https://boards.rossmanngroup.com/thr...-ground.37575/
    • karoliens
      • 18
      • Denmark
      Thank you for a quick reply. I've read that thread already but I was hoping maybe someone remembers from the top of their head normal reading on that rail.
      I'll hook it up to the power supply and I see what it shows. With older MacBooks that use MagSafe1 and MaSafe2 I've cut the cable with lightning connector ant connected it to the power supply for troubleshooting.
      Do I need to buy genuine USB-C charging brick to do the same for these newer models as well?
      • mon2
        • 14677
        You do not require the genuine USB-C power supply to power the macbook models. We have used LVSUN 90-95W models with success.
        Power delivery is an industry specification but you should purchase a unit with 20V support. More power the better. A branded version is preferred over no names. We have met LVSUN at past trade fairs in HK and they are a solid company. At the fair, we purchased this unit for ~$18 USD. It retails for ~60+ USD in the market. The unit worked well till we applied it to a butchered logic board from Ebay - Ebay refunded our money in full and allowed us to keep the macbook sold by this hack.
        • karoliens
          • 18
          • Denmark
          So you just cut the end of non-genuine USB-C brick and connect it to PSU? I suppose I could also use USB-C ammeter. I've see Louis using one for troubleshooting.
          • mon2
            • 14677
            No - no cutting required.
            Normal use is to use the power adapter as-is. To monitor the voltage and current draw from the external power adapter, apply a USB Type C meter / dongle like the T66C from RD (we use this one in the shop):
            Works very well and is accurate (our white meter which is cheaper fails to show us low current draw yet the T66C works fine):
            https://www.aliexpress.com/item/32968303350.html
            This one is cheaper but shows 0mA while the true current draw is 28mA-30mA on the T66C:
            https://www.aliexpress.com/item/3306...d=0LXuSrx85Qze
            So your external power adapter will plug into this meter -> the meter plugs into your macbook or any Type C product -> meter will offer the details of the power delivery contract being used with a live update on the current draw.
            Be sure that you select the BIDIRECTIONAL designs like the above otherwise, the meter will not function properly.
            Beside the above, there are these Type C cable heads that may work for your PSU use (personally do not recommend it but is an option):
            https://www.aliexpress.com/item/1005...d=Why2vY2PzlFP
            The above should be close but as noted, not recommended. The Type C spec is required to send out 5v by default -> after the ACE controller IC on the logic board negotiating, the external power adapter then shifts from 5v upto 20v. With this PSU cable, you will always be sending out 20v so IMHO, it is not an accurate representation of what the official adapter will be doing.
            Still recommend that you purchase a quality 100W PD compliant adapter with 20v support + the TC66C tool. Rest are extra gravy if you choose to buy them.
            Here is another option that may be better than the above cable only solution:
            https://www.aliexpress.com/item/1005...d=m8cyIZpv6V4U
            So for this to work @ 20V 5A, you MUST purchase a suitable E-marker style cable with PD support. If you DO NOT, the cable will be a passive one and max current is 3A. Just a FYI. Then apply your PSU to this brick -> then the USB C e-marker cable to the TC66C to monitor the voltage / current -> dock to your macbook. Now your PSU is driving the setup.
            Personally have never used this product so no idea on how well it will work. </Disclosure>
            • karoliens
              • 18
              • Denmark
              Thank you for explanation.
              • pcardoso73
                iMac power supply short-circuit diode to ground
                by pcardoso73
                I have an iMac with the power supply reference: ADP-200DFB.
                This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
                With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
                As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
                06-09-2020, 08:47 AM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • MalodicOne
                macbook pro 820-02100 5v 0 amp
                by MalodicOne
                Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
                Tested all CD3217 and RAA489900:
                UF400
                PP3v3_UPC0_LDO- 3.48v, .473 Diode
                PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
                USBC0_CC1- 0v, .455 Diode
                USBC0_CC2- 1.66v, .454 Diode...
                07-25-2025, 10:49 AM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • chickenhawk88
                RAZER BLADE 15 2021 MODEL, No power, shorted rails.
                by chickenhawk88
                The laptop I am working on is RAZER BLADE 15 , RZ09-0369, the motherboard is DA560 VER 4.0. The original fault was it powered up with keyboard rgb on and no video on screen/hdmi. I found corrosion on memory module that leaked onto the memory socket. I cleaned the memory socket and was able to boot normal with other memory socket with good memory. I really should have stopped at this point as everything was working except for the one bad memory slot.
                I wanted to find out what was wrong with the other memory slot. I replaced a 330uf cap, a buck converter on back of board and when i...
                05-15-2024, 06:37 PM
