Picked this up today for something to do and did a quick check of it. It does have 5 volt stby. Can't find much about this low end TV and wondering where I could find a schematic on the boards. I checked caps, diodes, etc. but have not gone thru the small smd parts. Thanks
insignia ns-321430a11 dead no led no nuttin
Re: insignia ns-321430a11 dead no led no nuttin
The white connector on the right side of the power supply/inverter board has labels for each pin. What are the DC Voltage readings of each pin when the TV is OFF and when the TV is ON. Please list the readings with the name of each pin next to the readings.Never stop learning
OK, the main board is getting the 5V STANDBY Voltage to run but it is not sending the PWR (PS_ON) to turn on the rest of the power supply, it is also not sending the BO (BL_ON (Backlights On)) either, so the main board is not working.
You can try disconnecting the cable between the main board and the T-CON board to see if it will make any difference, if not, then you should do visual inspection of the both side of the main board to see if it has any damaged parts.
I wonder if it was damaged by surges or lighting.
Also check shopjimmy to see how much the replacement will be, to do component level repair I hope you will have all the tools for SMD repair.Never stop learning
Really appreciate the help. I had come to the conclusion it had to be the main but needed an educated opinion. Have tried all I know that is why I would like a schematic but, that's life. I have done some smd work like an eeprom on a vizio but with my tools it is aggravating, but can be done. I am going to try and figure this out if possible. Just fiddling around, I found an area on the main with an infrared thermometer that was 153 degrees while everyting else was was 61 degress being out in the garage with a small gas heater. tried spray and cooled it but nothing. Anyway, thanks so much.Comment
Well, still messin with this main board. Too stubborn to give up yet. Just posting again to see if anyone can direct me to a schematic on main board. Thought I had found the problem with a voltage regulator # LD1117a/G33ANH. Had 5V going in and 1.8v coming out and had in my head it should be 3.3v, but just guessing. Had an old board I had and found a #AS1117L-33/B0548 that had same specs I thought and replaced it and still get 1.8V. Anyway, will probably end up getting other board but thought I would post one more time for schematic. ThanksComment
Is the suspect regulator getting particularly warm or hot?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
It is not getting hot. But there is an area in between c77 and c130 just on the board that is 187 degrees f. The regulator is only 100.7. Will include pic. Don't look at my crappy soldering on regulator. At least this blind 64 year old got it on there. Hope the pic will show.Comment
Thanks for the repair follow-up.Never stop learning
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... -
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos - Loading...
