White Vertical Bar / Line on left side of LED Smart Samsung un55b8000xfxza
  • maiden790
    • Nov 2014
    • 94
    Hey folks Ive been searching and searching for an answer and I'm scratching my head bald from this tv. Ill run you through of what condition I got this tv in
    1. Plugged the TV in and it powered up with a white screen / menu / everything
    2. Also had a White line on the left of the screen
    3. Did some troubleshooting / research and found out a couple of the diodes or transistors were shorted out on the T-con LJ94-02826H
    4. Purchased a new T-con (LJ94-02826K) for a for a slightly different model UN55B8500XFXZA (but everything lined up fine)
    5. New T-con fixed the color issue and can now see everything great
    6. Did not however fix the dreadful white line / bar on the left of the screen
    My question is, what should I try next?
    Im 96% positive that its not the panel itself that is broken and was thinking it was the VDSL, but it doesn't have any signs of damage nor does it distort the picture at all when I push / pull / wiggle it around.
    Any suggestions?
    Here are some pics of what Im working with here
    1st pic is the symptomatic screen, then the model number, then the OLD broken T-con, then just some pictures of the guts. Tried to be as detailed as possible to avoid questions haha Thank you!
    one mans is another ones treasure
    Re: White Vertical Bar / Line on left side of LED Smart Samsung un55b8000xfxza
    To me, it is almost certainly a bad panel. I'd like to be proven wrong, but it is very common on Samsung LCD&LED-LCD TVs.
    • maiden790
      • Nov 2014
      • 94
      Thanks Tom , I just cant put it back on the curbside just yet! I havent lost faith in it haha
      Is there anything else that it could possible be? And could using a different T-con be the problem at all or are they pretty much universal?
      • sugar_ray
        • Dec 2012
        • 121
        I'm with Tom. Unfortunately a different Tcon may be just a shot in the dark. I have run into several of these symptoms just like yours. Regardless of make, a fixed line like that has always meant a bad panel. Which, by now, most realize is the kiss of death and not worth saving!!
        However, bright side.......sounds like you have some good known working boards in that set that are sellable!! PS,.Tcon, etc.....
          Main is also good, and worth a pretty penny.
          • maiden790
            • Nov 2014
            • 94
            DanDado I guess it's a loss cause haha oh well at least I know for next time. It was definitely a project that taught me a lot about working on tv's but I guess I'll chuck her to the curb after I part it out :'( I'll be sure to beat it like a red headed step child for one last hope it may fix itself haha thanks guys for all your help !
            • maiden790
              • Nov 2014
              • 94
              Found the problem with the white bars, I'm assuming I would be able to purchase a new one and swap it out? What is this even called??
                Nope, that part is bonded to the panel. How would you replace it? Very common for water to damage LED-backlit LCD TVs.
                • maiden790
                  • Nov 2014
                  • 94
                  yea thats what i was asking you.. thanks
                  • Shinju
                    • Mar 2014
                    • 1239
                    Windex/water victim!
                    Toasted!
                    • electronicsurplus
                      • 210
                      That part is called the address Buffer. It USED to be impossible to replace but, Now we have found Z Axis Dual sided Tape from Adafruit.com. (This adhesive tape allows voltage and signals ONLY to go through it and NOT across it) If that makes any sense to you (I agree that it is very confusing) We have had a 60% success using the tape
                      Just wanted to add our 2 cents (sense)
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Well your chatting BS there because you can rebond the ribbon back to the tab board but you cant rebond it to the panel at all ! The traces that go to each address line are way too small.
                          Not to mention alignment. You're talking about getting it aligned within about 50um or so. That's 0.05mm or 2/1000 inches!
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Plus the tape costs a small fortune, lasts only 3 months and you gotta keep it in the freezer.
                            Where you gonna get a new address-tab to replace that rotted out one?
                            TELEFIX
                            • tech9pc
                              Samsung QN65Q80AAFXZC QLED TV has a white vertical Bar
                              by tech9pc
                              Hi all Happy Holidays! Was just wondering if you think this white vertical bar would be fixable. Maybe bad TCon or ribbon cable? Contemplating trading a 50 inch Hisense 4K Roku for the Samsung but might get burned lol. The Samsung is model QN65Q80AAFXZC QLED TV has a white vertical Bar. Any thought appreciated. Thanks.
                              12-24-2023, 11:28 AM
                            • bdalkiran
                              55EC930V white vertical line appeared (need help)
                              by bdalkiran
                              Dear All,
                              I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                              Please advice how to proceed and what is the...
                              01-13-2023, 04:16 PM
                            • mrsith
                              Samsung UE58TU7100K - no picture, vertical line
                              by mrsith
                              Hi.
                              Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                              This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                              Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                              02-07-2023, 11:18 AM
                              09-07-2024, 05:50 AM
                            • iampivot
                              Samsung 4K LCD white vertical banding in center
                              by iampivot
                              I'm troubleshooting a Samsung LS28D590DS 28" 4K monitor which has white vertical banding in the center of the LCD panel. The image looks like it's distorted slightly as well in the middle. Am wondering if this could be caused by the panel, t-con board or the main board?
                              04-03-2022, 09:54 AM
