Westinghouse TX-47F430S, weird colors and popping sound now nothing
  • bobotech
    • Aug 2004
    • 14
    Got this 47" tv a while ago. It powered up and I saw the W logo on the screen so I bought it for 15 dollars at the recycler.
    Finally got around to looking at it today. Powered it up and hooked up a source to it. The colors were off. It was like looking at a 3 gun RPTV that has the alignment of the guns off so you end up with that weird wrong colors and so on. Even the colors in the menus weren't right.
    I then tore it apart and looked at the mainboard and the power board. Everything looks good. No leaking caps or anything. I didn't touch either of the boards on the left/right (Inverter? Driver boards?).
    Put it all together and powered it up. The W came up and it still looked odd. I then and moved the tv a little bit and heard the distinctive zzzz sound of a short circuit. Unplugged it and looked, could't find anything.
    Plugged it back in and saw a spark coming from the left side inverter/driverboard. Unplugged it and opened up the cover to the untouched driver board to see if i could see anything. I then noticed that the high voltage power cable going to the CFL bulb was barely inserted. That is where the spark appeared to come from. I plugged everything back together and powered the tv back on. No zzzzz sound and everything seemed to be okay except now I get no picture. What did I do?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Westinghouse TX-47F430S, weird colors and popping sound now nothing
    We get no pictures either??
    https://www.badcaps.net/forum/showthread.php?t=39740..
    Find your Tcon as well and put up a good clear picture of that.
    Test all fuses and tell us which you have tested so we know.
    • Loki_Fido
      (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
      by Loki_Fido
      Hi folks,
      This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
      I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
      BIOS - XMC 25RU128CH10 (1.8v)
      What the heck is this? I looked all over the MB. This is the only bios.
      When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
      03-20-2025, 01:57 AM
    • silikon77
      Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
      by silikon77
      Hi!
      Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
      Found some advices watching youtube nad came up with this:
      It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
      I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
      See attached picture.
      I tried a few combinations to block individual clock...
      01-02-2025, 02:26 PM
      APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
      This started a few days ago and does this about every 8 hours
      After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
      The battery backup is about 3 or 4 years old
      Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
      06-02-2024, 02:30 AM
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • alro7779
      Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
      by alro7779
      Hello, guys!
      I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
      Alex....
      10-03-2025, 05:49 PM
