Kdl-40ex701
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Kdl-40ex701
    Hello
    I have problem with my TV KDL-40EX701 (SONY)
    it's 2 time led flashing
    sometimes doesn't blinks the green led Ok but the Back light not working
    and no sound no picture
    ( I change the system board but the same problem )
    I need some help
    what's the solution for this problem , I want service manual please .
    Electronic Engineer from Syria,Aleppo
    Re: Kdl-40ex701
    ex700 may be close:
    http://elektrotanya.com/?q=showresul...oria=&kat2=all
    • abdekader
      • Jul 2014
      • 73
      • Turkey
      Re: Kdl-40ex701
      I want error codes from service manual , that's different
        Re: Kdl-40ex701
        Did you download the manual and look at page 9 for 2-blink error code?
        STBY LED Flash time
        Service menu Item name(Screen Display) Diagnostic Item Description
        2 = MAIN_POWE Main Power Over Voltage Protection
        Originally posted by abdekader
        Hello
        I need some help
        • abdekader
          • Jul 2014
          • 73
          • Turkey
          Re: Kdl-40ex701
          OK , but this is the same 40EX701 error code ?
          and I want Schematic to this Power board if you can
          http://www.boardss.co.uk/index.php?m...roducts_id=794
          Regards
            Re: Kdl-40ex701
            Well did you look at page 3 of the service manual for the models?
            What is the P/N and the version numbers as printed on the power supply board?
            Good clear pictures of the board?
            • abdekader
              • Jul 2014
              • 73
              • Turkey
              Re: Kdl-40ex701
              the same thanks
              if you have schematic to this power , I want it
              do you know what's the problem in this power
                Re: Kdl-40ex701
                See if your TV is the same as shown in this Training manual
                  Re: Kdl-40ex701
                  the same thanks
                  Please show me the pictures and give me the P/N as printed the board.
                    Re: Kdl-40ex701
                    Is this the exact power supply board?
                    http://www.shopjimmy.com/catalogsear...NY+KDL-40EX700
                    • abdekader
                      • Jul 2014
                      • 73
                      • Turkey
                      Re: Kdl-40ex701
                      NO this different
                      the first manual good
                      but now I want schematic to power board (1-881-956-12) for repair it
                      if you know in power board what's the problem tell me
                      (3.3v ok) (AC_det =3.3 OK) 5v OK but no 12v
                      • abdekader
                        • Jul 2014
                        • 73
                        • Turkey
                        Re: Kdl-40ex701
                        the power board
                        what's the common problems in this board ?
                          Re: Kdl-40ex701
                          I do not have any info on this power supply board.
                          I found this training manual.
                          Protection ShutdownCritical voltages and circuit operations are monitored by the CPU on the BAL board. If a fault is detected the unit will be forced to shut down by the CPU. The monitored circuit in which the fault occurred will cause the CPU to flash the standby LED in groups of repeating sequences. The number of blinks in these groups identifies which voltage or circuit caused the protection event.Not all of the available protect codes are used. Models that are LED backlit do not use the 4-blink balancer error as this circuit is found in models that are backlit with fluorescent lamps. The following list contains the protect circuits and diagnostics codes used in the EX700 models. The troubleshooting flowchart in Figure 3-5 provides guidance in locating the possible component causing the shutdown.
                          2X: A loss of REG12V from the power supply triggers this protect event. The causes range from a failure of the REG12V line, power supply failure, power supply shutdown, an open string of LED backlights, or a problem with the detection circuit on the BAL board.If a failure occurs on the power supply board that causes a loss of the REG12V line, the standby LED will not light when power is applied to the television. After about 10 seconds, the standby LED will light briefly and begin blinking in groups of 2.If one of the series strings of LED backlights opens, an over-voltage protect circuit for the LED drive lines turns off the main relay. This causes the same 2-blink error code as a loss of REG12V. The difference to observe is the presence of the red standby LED when AC power is applied. The green power LED lights for approximately 10 seconds when the power is turned on followed by a shutdown of the unit with a 2-blink error flashing on the standby LED.
                          3X: The REG 5V and D3.3V source originating on the BAL board is monitored for low-voltage conditions by CPU IC5000. A failure causing a 3X shutdown would require replacement of the BAL board.
                          5X: A communications error with the high frame-rate or timing control circuits has occurred. Since both of these circuits are located on the TCON board, replacement of the board should remedy the problem. In rare cases a loose or defective LVDS cable could be the cause. If the TCON board is not available as a separate part, the entire LCD panel must be replaced.
                          6X: Although labeled as โ€œbacklight errorโ€, this condition is caused by a failure of the converter circuit generating the voltage and PWM signals to control the backlight LED's. Replacement of the power supply board is necessary.
                          7X: A digital thermometer IC located on the BAL board provides a temperature reading of the chassis and LCD panel. If the temperature exceeds a pre-determined point the unit will shut down. If this problem occurs immediately at turn-on, the temperature sensing IC has failed and replacement of the BAL board is required. If this occurs after the unit has been running for a while, check for ventilation issues that could cause the unit to run hotter than normal.
                          • H34TO
                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                            by H34TO
                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                            06-17-2025, 07:17 AM
                          • Chrissygizmo
                            Sony KD-55XG9505 lines on screen problem
                            by Chrissygizmo
                            Hello again everyone,
                            This is my latest mission, to try getting this Sony tv back to normal working orderโ€ฆ
                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                            02-19-2025, 11:31 AM
                          • stav242
                            Sony KD-55X8509C white flashing/pulsing LED
                            by stav242
                            I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
                            On inspection, there was no physical issues.
                            I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
                            - this seems to indicate repairing required, done by Firmware update.
                            so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
                            Inserted the drive and repowered the TV.
                            LED changed to white flashing/pulsing ... and it sat there for over an hour.
                            i was unsure what was happening so repowered the TV and now it just...
                            01-08-2024, 07:39 AM
                          • pengamat_hebat
                            Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                            by pengamat_hebat
                            I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                            Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                            However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                            I also tried applying 3.3V to pin 3, but it still didn't work.
                            I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                            03-25-2025, 04:13 AM
                          • retrorepair
                            SONY KDL-40P3600 Picture Problem
                            by retrorepair
                            Hello gurus, hope you can assist me...
                            I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                            I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                            Thanks in advance.
                            10-11-2024, 05:12 PM
