Toshiba LED TV 40L1333b sound no picture
  • Locksocket
    • Nov 2016
    • 8
    • United Kingdom
    Re: Toshiba LED TV 40L1333b sound no picture
    Question, what's the chances of 9 leds blowing at once?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Possible, one could fail open then short the rest behind it due to the load being dumped onto them. Make sure your testing the correct pads though.
      • Locksocket
        • Nov 2016
        • 8
        • United Kingdom
        I've managed to test all the rest and they work. Also when I test the connector books from the green side strips I get a beep from the meter but it does show a number other than one.
        Sorry if that sounds odd but I'm very new to this.
        • Locksocket
          • Nov 2016
          • 8
          • United Kingdom
          Hey all, an update, I've repaired all the burnt out led s and now can test each and it will light up, but still when I power on the to the leds won't come on.
          Any advice please?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            So did you test the middle connector blocks ?
            • Locksocket
              • Nov 2016
              • 8
              • United Kingdom
              #26
              I have and they all seem fine.
              • Locksocket
                • Nov 2016
                • 8
                • United Kingdom
                #27
                Could you advice me on diagnostic on this power board please?http://m.imgur.com/RVfB3NF
                Or how to diagnose this http://m.imgur.com/BNn1vaZ
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  Any advice please?
                  Is the polarity right on the ones you replaced. Each one will light but if polarity wrong strip won't light
                  • Locksocket
                    • Nov 2016
                    • 8
                    • United Kingdom
                    #29
                    I believe so, I use the meter on the trace before and after the stacked led and it lights up. I've done the mod on all connector blocks but I'm a complete noobs when it comes to checking boards. I would assume the power board is working because when I have the screen connected I can see the menu options clearly. I tried another inverter board but still nothing ( the blue board I posted a picture of)
                    • Locksocket
                      • Nov 2016
                      • 8
                      • United Kingdom
                      #30
                      Any advice?
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        If you had bad led's I would say that is still the problem. Since I assume you are checking them one by one you really don't know if whole strip is lighting or not. I have a tester. I just repaired led's last night. I desolder and replace individually. I checked and they light up individually but when I checked whole string it did not light. So for me if you cannot light whole string you do not know for sure if all going to work.
                          How many strings of LED being used in this panel?
                          All connected as ONE long string?
                          Can I see the pictures of the LED connector with the connector in place and also the bottom side of the board where the LED connector is?
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • jord4231
                            Toshiba 37AV500A Regza TV good power supply no sound no picture
                            by jord4231
                            Hi Everyone,
                            I'm working on a Toshiba 37AV500A Regza TV.
                            The issue:
                            TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                            The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                            I checked the PSU voltages and everything looked good.
                            No bulging caps or signs of heat.
                            24v aud = 24.41v
                            12v = 11.98v
                            5v = 5.062
                            p_o/f = Goes high...
                            03-29-2022, 09:21 PM
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • jchang
                            Samsung UN70NU6900F no picture and no sound
                            by jchang
                            Hi all
                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                            Symptom:
                            No picture no sound.
                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                            No sound at all.
                            What I tried:
                            1. I tried unplugging the left or right ribbon...
                            01-09-2023, 06:28 PM
