RCA 32LB30RQD - Power on, No picture, sound, or backlight
Re: RCA 32LB30RQD - Power on, No picture, sound, or backlight
You were forcing it high with lots of current.
Right now you can connect the E and B of the T1 together which then you will see the Collector Voltage to go up (which is BL_ON = HIGH).Never stop learning
I tried that by grounding the base and backlights went on but tcon didn't turn on. Anyway to trigger that as well?Comment
The T-CON on is also generated by the processor, so you have to turn the TV on so the processor will send out the signals,
The signals are on its own pin of the processor, one pin for PS_ON, one pin for BL_ON, pin for T-CON on.
"I tried that by grounding the base and backlights went on but tcon didn't turn on." Right now the processor is sending out the PS_ON, but not the T-CON on, and intermittent BL_ON.
"Anyway to trigger that as well?" To do that you will need to locate the MOSFET which is used as a switch to supply the Voltage to the T-CON.Last edited by budm; 11-26-2014, 06:22 PM.Never stop learning
FIXED: RCA 32LB30RQD - Power on, No picture, sound, or backlight
Update: Was bored and decided to try re flowing the processor just for the heck of it. Well surprisingly the tv has been working perfectly since. Multiple cycling and every time it's responding as it should.
So something to try if someone ever encounters a similar issue after a power surge.Last edited by caphair; 11-29-2014, 03:58 PM.Comment
Assuming...7 Photos -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... - Loading...
