RCA 32LB30RQD - Power on, No picture, sound, or backlight
  • caphair
    • Nov 2011
    • 1249
    All the voltages are present from standby 5v to 24v to inverter. After some more testing, I noticed the BL_ON command only goes to 0.06v. The BL_ON command comes from the mainboard labeled "inverter dc" as shown in one of the pics which when measured from top down gave 0v 5v 0v (this last 0v connector is the BL_ON on inverter side) . Is it safe to try jumping this with the 5v next to it to see if the picture comes on?
    Also to note, pressing the power button after it has been turned on does not turn it off, need to unplug the set at that point.
    The person I'm troubleshooting this for says the fault occured after a power surge.
  • caphair
    • Nov 2011
    • 1249
    Re: RCA 32LB30RQD - Power on, No picture, sound, or backlight
    Fuses on the t-con and inverter both tested ok. Would there be any on the mainboard?
      "Also to note, pressing the power button after it has been turned on does not turn it off" That indicate main board problem when you do not have control to turn the TV off.
      There are some 3-pin Voltage regulators IC that you may want to check the Voltages on.
      https://www.badcaps.net/forum/showthread.php?t=22231
      • caphair
        • Nov 2011
        • 1249
        Ok here are the measurements to the regulators on the main board.
        They will be posted in this order pins 1, 2, 3 (left to right with tab on top)
        U1 - 1117AG
        0v
        1.24v
        2.97v
        U2 - 1117B 33
        0v
        3.3v
        4.94v
        U4 - 1117AG
        0v
        1.24v
        3.30v
        U6 - 1117AG
        0.58v
        1.83v
        3.30v
        There's 1.24v present on the three adjustable regulators across pins 1 and 2
          They are OK
          I myself never have luck fixing the SAMSUNG main board.
          You can remove the wire from the BL_ON connector to the main board and then use the resistor to force on the backlights to see if you can get normal pictures and normal function of the TV.
            The input to U1 looks odd, 3V is an unusual rail voltage. Try testing that one again? Its output is good but maybe if that's supposed to be a 3.3V rail it could cause issues. Switching converter etc. for CPU logic/IO.
            • caphair
              • Nov 2011
              • 1249
              Originally posted by budm
              They are OK
              What value resistor, does it matter? Could I just short the 5v to bl_on using multimeter in current test mode?
              • caphair
                • Nov 2011
                • 1249
                Tested again, same values.
                  I see at least one switcher, U5. Near the power connector from the power supply. What is the part number of U5?
                    You have to disconnect the cable because if the switched transistor on the main board is on when you apply 5V it will draw lots current into fully on transistor and it not allow the BL_ON line to go high.
                    • caphair
                      • Nov 2011
                      • 1249
                      Ok so unplug and short 5v pin to bl_on pin of the connector? Do I need a resistor or can use a wire?
                      • caphair
                        • Nov 2011
                        • 1249
                        I'll take a look when I'm home later. Just left
                          I use 100~500 Ohms resistor.
                          • caphair
                            • Nov 2011
                            • 1249
                            i see at least one switcher, u5. Near the power connector from the power supply. What is the part number of u5?
                            fr9886
                            • caphair
                              • Nov 2011
                              • 1249
                              Used a 100ohm resistor and set fired up with a picture and now responds to power off.
                              Can I run it like this? Any idea from this what could be the bad component/s?
                                You need to trace that BL_ON connection of the main board to see where it goes to, it should be connected to a switched Transistor/MOSFET which is turned on by the processor, not going to be easy.
                                The BL_ON must be applied after PS_ON is applied to allow the power supply to become stable before the inverter kicks since it draw the most power from the power supply.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Yeah doesn't look easy I already tried a bit before the resistor thing. Weird though it worked the first try, went to connect to a source and now isn't working. Just turns on with backlight but doesn't give a picture with "no signal" as initial try
                                    I think your main board is dying.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      As in not repairable?
                                      I traced that bl_on pin to this cluster. Those two transistor looking components didn't measure any shorts in any pin configuration
                                        You need to check the E-B DC Voltage to see if it is biased on/off when the TV is turned on and off.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
