Toshiba 26HL37 : backlight on, sound on, no picture (white screen)
  • vizi0n
    • Nov 2014
    • 28
    Hi!
    I'm trying to fix a Toshiba LCD tv that has a randomly working display.
    Most of the time when I turn it on it will flash once as it usually does, then instead of coming up to the current source display I get a white image that will after a few seconds/minutes display very lightly colored vertical thin stripes. Once in a while it does work normally when I power it on, but next time I turn it on again, the gamble starts over.
    I have tried changing the t-con for a new one, same thing. I have actually tried 2 t-con (other than that first one that was in the tv when the problem appeared).
    What are my options about this? Main board? Panel? Is there any way for me to test this kind of problem with a regular multimeter or does this matter gets more serious and requires an oscilloscope?
    Here's a video of the startup sequence (volume was low, but you can hear it)
    https://www.youtube.com/watch?v=sv3jfWBw_bA
    Thanks for your help!
    Frank
    Re: Toshiba 26HL37 : backlight on, sound on, no picture (white screen)
    When the pictures disappear, do the backligts still stay on?
    • vizi0n
      • Nov 2014
      • 28
      The picture never shows when I power it on, only whiteish image. It will sometime power on and work normally, but thats like 1/50 chances. I've added a link to a video on Youtube showing the behavior in my first post.
      The backlight/inverter are working fine
      EDIT: I just recalled that once my son called me up a few weeks ago and said "dad, the tv's picture is frozen" and it was actually frozen on a frame and gradually becoming whitish. The sound kept running like usual.
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • jord4231
        Toshiba 37AV500A Regza TV good power supply no sound no picture
        by jord4231
        Hi Everyone,
        I'm working on a Toshiba 37AV500A Regza TV.
        The issue:
        TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
        The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
        I checked the PSU voltages and everything looked good.
        No bulging caps or signs of heat.
        24v aud = 24.41v
        12v = 11.98v
        5v = 5.062
        p_o/f = Goes high...
        03-29-2022, 09:21 PM
