Sony Bravia , KDL-32XBR4 clicks but won't turn on i change the power supply and still same problem
Sony Bravia KDL32L5000 clicks but won't turn on
Re: Sony Bravia KDL32L5000 clicks but won't turn on
You should post the correct model number ans stay on the same thread:
https://www.badcaps.net/forum/showth...974#post500974Never stop learning
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by pdsternsTV does nothing when turning on, if I do a power/-vol and then plug in I have a solid green light but nothing else. I purchased a harvested Power supply and Logic board. Installing the PS had no changes but the Logic board gave me 1 white flash an 4 or 5 repeating red flashes.I tried a firmware update using the update file 3 times with 3 recomended files, no power, insert thumb drive and and power up, nothing happened.
Board vendor says board is bad and will provide replacement but does not have any. Sony want $500 with $150 core refund.
Am I on the right track or should... -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by Abel BejanHello,
I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,... - Loading...
