Sony Bravia XBR-65A8F, no turn on
  • pdsterns
    • Oct 2022
    • 28
    TV does nothing when turning on, if I do a power/-vol and then plug in I have a solid green light but nothing else. I purchased a harvested Power supply and Logic board. Installing the PS had no changes but the Logic board gave me 1 white flash an 4 or 5 repeating red flashes.I tried a firmware update using the update file 3 times with 3 recomended files, no power, insert thumb drive and and power up, nothing happened.
    Board vendor says board is bad and will provide replacement but does not have any. Sony want $500 with $150 core refund.
    Am I on the right track or should I be checking something else
    TIA
    burns
  • pdsterns
    • Oct 2022
    • 28
    Re: Sony Bravia XBR-65A8F, no turn on
    Forget all the above, the Tcon board connectors were unpluged. Once I plugged them in the mother fired right up
    burns
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
    • brzostos
      HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
      by brzostos
      Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
      After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
      Original HP 150W power supply, the diode in the power socket lights...
      10-01-2024, 01:34 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
