LG RZ-37LZ31, no power, faulty KNP-3370 PSU
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    I have a LG RZ-27LZ31 LCD TV that doesn't power on. The 5V Stby are OK, but when you try to switch on, a relay clicks on the PSU several times but no other voltage comes from the PSU (5V, 12V, 18V, 24V).
    I've tried the PSU alone, making a bridge between the 5Vstby and the DPM line. Same results, so it's not a short in any other TV part.
    The PSU is a KN Powertek KNP-3370. The TV service manual doesn't include schematics from this board and I haven't found any.
    Any ideas? Which is the primary switching controller or regulator that I have to check first? I don't detect any shorts in switching mosfets, as far as I can check.
  • mscserbia
    • Dec 2013
    • 17
    • Serbia
    Re: LG RZ-37LZ31, no power, faulty KNP-3370 PSU
    Post some pictures of that power supply.
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      Not very good pics, but enough to start pointing zones to focus.
        Can you list the labels of all the pins on those two white connectors? I would like to know what the 'DPM' pin is.
        • Chungalin
          • Jul 2014
          • 423
          • Spain
          One:
          18V
          18V
          GND
          GND
          12V
          12V
          ACD
          GND
          5Vst
          DPM
          5V
          5V
          5V
          GND
          GND
          The other:
          24V
          24V
          24V
          24V
          24V
          GND
          GND
          GND
          GND
          GND
          12V
          12V
          GND
          33V
          Only 5Vst is present when powering the board.
            OK, I have no idea what 'DPM' stands for.
            But the bottom line is that the main board is not sending any signals back to the power supply board.
            When you bridge the 5VST and the DPM line, did you remove the DPM wire going back to the main board first?
            • Chungalin
              • Jul 2014
              • 423
              • Spain
              I'm trying the PSU alone on the desk, completely isolated from the TV. Unless the PSU has some kind of undercurrent protection, it's supposed that all those voltages have to show up once it's fixed...
                We need to find out what that DPM line goes to on the board. By the way, did you see the DPM goes HIGH when TV is turned on and goes LO when turned off? If it is control line then it should toggle LO-HI, HI-LO with power switch.
                Need to find SCH of this board or a working board to do comparison readings.
                • Chungalin
                  • Jul 2014
                  • 423
                  • Spain
                  Service manual available at ElectroTanya. Schematic of power connector at page 44. As you say, I noticed that when the TV wanted to turn on, DPM line went to 5V. Could not find what does ACD, schematics aren’t searchable. Thre’re no other control lines.
                    'ACD' is AC Detect (same as AC OK in some other brand)
                    • sordids999
                      • May 2013
                      • 2161
                      Hi Chungalin
                      did you ever fix this problem i have the same fault im trying to fix for a family member
                      • Chungalin
                        • Jul 2014
                        • 423
                        • Spain
                        Sorry Sordids, I forgot to suscribe to this thread and didn’t see your question. I never managed to repair this and now I’m salvaging boards from this TV and discard the remaining parts.
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                          DVR camera recorder switching power supply capacitor failure really
                          by sam_sam_sam
                          These cheap non brand capacitors at it again
                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                          Well at least I have the cameras back on line I to try the...
                          01-22-2022, 06:28 PM
