samsung UE32F5000AK led no backlight
+ More Options
Posts
  • painner
    • Aug 2011
    • 8
    Hello I am wondering if anyone can give me some advice I have a Samsung UE32F5000AK when I turn it on the screen stays blank. I can hear the TV working fine and when I hold a bright torch I can see a picture so I think it's the backlight gone. Can anyone advise me how to fix this as I bought another power board and that didn't fix my backlight?
    Re: samsung UE32F5000AK led no backlight
    It will be an open circuit LED in the backlight array, the TV panel needs to come apart to fix this.
    • painner
      • Aug 2011
      • 8
      many thanks for very quick reply so does that mean one of the leds has gone and I have to track down which one . Don't mind taking it apart again had the led strips out the other day wanted to see what voltage they where because I wondered if I could send that voltage through each strip to check if they were blown
        You can make 3VDC from two AA batteries and put 100 Ohms resistor in series with the positive to limit the through the LED, then you can test each LED on the strip one at a time to find out which one is bad, the Anode is positive, Cathode is negative.
        • painner
          • Aug 2011
          • 8
          many thanks for all your help and very helpful advice will look forward to trying this out
          • painner
            • Aug 2011
            • 8
            Many thanks found two blown leds jumped that strip to see if works and came on. so now just got to find where to get some spares in UK. Many thanks for you knowledge
              09-07-2024, 05:50 AM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
            • sansanpartida
              Samsung QE82Q70RAT no backlight
              by sansanpartida
              Hi everyone!
              Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
              My issue: No backlight.
              Model: QE82Q70RAT
              Type No: QE82Q70RAT
              The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
              So hopefully, I can fix this cheaper.
              05-22-2024, 06:56 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • Warrensmith
              Samsung BN44-00807E Low Backlight
              by Warrensmith
              Symptom is dim backlight - this set came in with almost no backlight.
              Samsung UN55JU6500FX2A
              1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
              2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
              Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
              10-27-2022, 07:09 AM
