Panasonic TC-P55ST60. 7 flashes
  • planky
    • Nov 2014
    • 7
    I have a Panasonic plasma tv - model # TC-P55ST60. I bought it from Sears in May 2013. A few days ago it shut down suddenly with the power light flashing 7 times in sequence. I have changed the P, SC and SS boards (bought from ShopJimmys) with no success. Would appreciate any suggestions/assistance with trying to trouble shoot the problem and arriving at a solution
    Re: Panasonic TC-P55ST60. 7 flashes
    Could be bad SU/SD boards. Can you supply pictures of the parts inside the set and one with the whole back cover off?
    • planky
      • Nov 2014
      • 7
      tom66,
      Thanks for your quick and helpful response. Both boards are in fact on order and I hope to receive and have them installed in a few days. If this does not prove to be the solution, I will forward the photos suggested .In any event, I will be in touch again a.s.a.p. Thank you again!
        Er... are you aware of the possiblity of testing them? "Could be" is not a DEFINITE...!
        Also you can get bad SU/SD which can DAMAGE the SC board. So it is important to know if they are all in working order.
        • planky
          • Nov 2014
          • 7
          How do I test?
            Please supply clear photos of them. You will need a digital multimeter.
            • freakaftr8
              • Oct 2012
              • 3743
              You could have pulled off the su and sd boards first and tested the sc board with a jumper. I have seen su and sd board's damage the sc. As.a matter of fact I just repaired a 65 inch the same way.
              • planky
                • Nov 2014
                • 7
                Hope the attached are suitable
                • planky
                  • Nov 2014
                  • 7
                  Forwarding better photos of the SU and SD boards.
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • AquaMan Ua
                    by AquaMan Ua
                    05-17-2025, 09:40 AM
                  • odie34
                    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                    by odie34
                    I am a hobbyist (not a professional) so please be gentle...
                    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                    02-18-2024, 09:11 AM
                    I bought three of these Sparkle Power FSP460-60GLC - Computer Power Supply 460Watts recap need
                    by sam_sam_sam
                    I have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
                    Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
                    https://theelectronicgoldmine.com/products/g28149
                    I have one old computer that...
                    07-18-2024, 06:55 PM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
