LG 50PG20 plasma no power issue
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 50PG20 plasma no power issue
    i can see two one just below the two large capacitors (its a white fuse with silver ends) and the other bottom left of board by the red/blue mains wire connector.
    • zell66
      • Nov 2014
      • 35
      • usa
      fuse F101 main fuse is good 0.2
      308v fuse F801 does not read anything.
      • zell66
        • Nov 2014
        • 35
        • usa
          That would be a problem then. Check all the devices along the small long heatsink in the middle of the power supply board. I would take a guess a MOSFET or switching IC is shorted.
          • zell66
            • Nov 2014
            • 35
            • usa
            sorry you realy lost me there. I have no idea what a MOSFET or switching IC is??
              You can see devices mounted to that heatsink, right?
              Check them for shorts. Typically, they are MOSFETs (3 legged devices.) You do not need to remove them from the board to do the test.
              To test for shorts, use the same mode on your meter that you used for fuses. Except this time, a reading of near zero is bad. Test all three combinations of pins (pins 1-2, 2-3 and 3-1) the polarity does not matter for a quick check like this.
              If you find a device with more than 3 legs on that heatsink, please advise the part number printed on it so we can indicate where to test.
              • zell66
                • Nov 2014
                • 35
                • usa
                #27
                ok thank you for that explanation!!
                on most I am getting 0 but on some when it registers 0 it flashes 125 or 65 first then 0.
                going from left to right on power supply board the second heat sink (?) registers 0 or close to 0.
                the middle one registers all above 0
                  Ok, would you read off the part number of each of those devices so I can check if those readings make sense. It will be printed on the front of it, maybe quite faint so use a light if necessary.
                  • zell66
                    • Nov 2014
                    • 35
                    • usa
                    #29
                    sd20ng(or 6)0
                    grs749
                    this is the only on I can read with out removing parts.
                    this number is printed on the left face of the center 3 prong devise on heat sink #2 or second from right
                      They are probably SD20N60
                      http://images.mcmanager.co.uk/ebayfi...-SD20N60-1.jpg
                      You would need to replace both of these, and the driver IC responsible for them.
                      Or the entire power board.
                      • zell66
                        • Nov 2014
                        • 35
                        • usa
                        #31
                        would it be easier to just replace the entire bored? If so is there a specific board I need to look for on ebay?
                        • zell66
                          • Nov 2014
                          • 35
                          • usa
                          #32
                          or do I buy a power supply component kit and resolder the devices to the board
                            If you have never done surface mount repair before, the best option would be a board replacement.
                            • zell66
                              • Nov 2014
                              • 35
                              • usa
                              #34
                              it has been many years since i have done sodering but I can give it a try.
                              http://www.ebay.com/itm/LG-EAY413609...item3a9ab98d62
                                Looks mostly through hole, should be fairly easy.
                                • zell66
                                  • Nov 2014
                                  • 35
                                  • usa
                                  #36
                                  ok that ebay link i send you. is this the type of parts I need?
                                    They don't list exactly what is included so I wouldn't be able to say.
                                    • zell66
                                      • Nov 2014
                                      • 35
                                      • usa
                                      #38
                                      I had a TV repair place look over board and agreed with me, 1 bad fuse and D603 on heatsink #2 is bad. Finding fuse is no problem, D603 is harder to find.
                                      fcf20b0 i think is part number
                                      • zell66
                                        • Nov 2014
                                        • 35
                                        • usa
                                        #39
                                        this is the part i cant find, marked as d603
                                        • zell66
                                          • Nov 2014
                                          • 35
                                          • usa
                                          #40
                                          in the picture it is the middle one with a triangle peg pattern.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
                                          • lp20th
                                            Samsung Plasma TV Power Supply Issue
                                            by lp20th
                                            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                            11-28-2023, 10:28 AM
                                          • justice171
                                            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                            by justice171
                                            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                            1. Verified that all critical voltages are present:
                                              • 3.3V and 5V are always present if DC is plugged.
                                              • 1.8V on the BIOS chip is present.
                                            2. Checked the power button functionality:
                                              • When pressed, the voltage drops to 0V, indicating the button is functional.
                                            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                              • Confirmed connectivity is intact, ruling out issues
                                            11-26-2024, 12:39 AM
                                          • claws77
                                            lenovo flex 5 14itl05 power sequence issue
                                            by claws77
                                            hi guys, my motherboard will not start no matter what
                                            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                            but rest nothing happens no sign of life.
                                            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                            i have no knowledge of motherboards ....
                                            10-20-2024, 02:48 PM
