LG 50PG20 plasma no power issue
  • zell66
    • Nov 2014
    • 35
    • usa
    #41
    Re: LG 50PG20 plasma no power issue
    where would i purchase a new power supply board for this tv?
    • rccrasher65
      • Mar 2014
      • 626
      Try ShopJimmy.com, or Ebay. Just be careful when buying from ebay, look for good seller with a return policy.
      • almanu04
        • Aug 2015
        • usa
        #43
        Originally posted by tom66
        You can see devices mounted to that heatsink, right?
        Check them for shorts. Typically, they are MOSFETs (3 legged devices.) You do not need to remove them from the board to do the test.
        To test for shorts, use the same mode on your meter that you used for fuses. Except this time, a reading of near zero is bad. Test all three combinations of pins (pins 1-2, 2-3 and 3-1) the polarity does not matter for a quick check like this.
        If you find a device with more than 3 legs on that heatsink, please advise the part number printed on it so we can indicate where to test.
        hi hello! my name is Al. I'm sorry for the interruption. I'm also having the same issue, but mine reads .5 and 1.5. I'm new to this too. Is mine bad too with those readings?
        • Terryfictv
          • Mar 2011
          • 124
          Same basic steps...Do you have soldering experience ?
          IF NOT, it might be easier for you to replace the board !
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Cooperr
            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
            by Cooperr
            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
            10-21-2025, 01:11 PM
          • lp20th
            Samsung Plasma TV Power Supply Issue
            by lp20th
            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
            11-28-2023, 10:28 AM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
